40x60x14 Shop
   / 40x60x14 Shop #1
JHurt
Gold Member
Hedrick, IN
M Farmall
Finally broke ground on my shop last week. Weather has been good, and looks to stay good into next week, so hopefully they can get it knocked out by Thanksgiving.
The original pad last March.
Ovrszd hauled a LOT of fill after the wife decided that she wanted to move the shop farther south than originally planned. I can't remember now how many scraper loads it was, but it was a BUNCH. I was the resident packer. Luckily, it had all summer to settle, and it ended up looking great when they did start on the shop.
Getting the pad ready last week.
Rebar and foam in yesterday. Should get the floor heat ran today, and hopefully pour concrete on Thursday.
   / 40x60x14 Shop #2
Great pictures. Keep them coming please. Hopefully it will go without any problems. :thumbsup:
   / 40x60x14 Shop #3
That's a lot of rebar!!!!! How far apart is each stick? Will you be adding chairs before your pour? I never trust a contractor that tells me that they can pick it up while spreading the concrete and that it will stay there while they walk on it. In every case, the rebar ends up at the bottom of the concrete and you no longer gain any strength from it.
Concrete chairs are the only way to ensure that the rebar remains in the middle, or lower 1/3 of the concrete.
   / 40x60x14 Shop
I didn't measure it, but I would say they are 1-1.5' apart. We haven't discussed chairs, but I have seen one of his pours that was similar to this, and it had chairs. I don't recall exactly how it was done, but he added them when he was wiring the pipe to the rebar.
   / 40x60x14 Shop #5
Very nice foundation work !! Is this going to be a 'stick' built building ? Look forward to your progress.....
   / 40x60x14 Shop
It is going to be a stick built building. Spray foam insulation on the walls, and blow in insulation in the ceiling. It will have a metal panel ceiling, and we are still working on what the walls will be. Builder wants to do metal panel walls, and we want OSB walls. I think it will help absorb the noise. Builder is super particular about his buildings and hates the look of OSB. So far we have "maybe" decided on plywood stood on end so that it was 8ft high, and then metal liner from there on up.
   / 40x60x14 Shop
Pouring concrete tomorrow morning!
   / 40x60x14 Shop #8
Guess it depends what you are going to use the shop for. I would go with the OSB and metal on top as you 'maybe' want to do. I would be afraid I would bang and dent the metal wall panels. OSB would take more abuse. I think you can get the OSB in 10' lengths.
   / 40x60x14 Shop #10
I used to hate Obnoxious Soft Board, once damp it swelled up, flaked off and was useless. Then I found Advantech.
What are your choices for plywood? That could look nice.
Looks to be close to 40 yds if you are going 5 inches thick !!! I always form up a extra area for leftover concrete. Just something you might need to put outside things on. Always a fun time when the trucks show up !!!
Form up a couple of ballast blocks for the tractor.
2007 KENWORTH W900B (A58214)
2007 KENWORTH...
HITACHI WEDGEDOCK COUPLER (A58376)
HITACHI WEDGEDOCK...
UNUSED QUICK ATTACH STUMP BUCKET (A58375)
UNUSED QUICK...
2006 Case 621D (A57148)
2006 Case 621D...
*NEW* 50 Traffic Cones (A55272)
*NEW* 50 Traffic...
INTERNATIONAL 400 CYCLO 4 ROW CORN PLANTER (A58375)
INTERNATIONAL 400...
