The Carolina Carports install crew for our garage has had a rough week. They were down one man (of a three man crew) yesterday for a large install (18'x60') colored black and in direct sun on a sunny, hot & humid day. It pretty much wiped them out by the end of the day and They couldn't make our appointed install slot and came out today. In the end, still one man down & feeling cumulative effects of the heat, the two installers couldn't finish the whole job today & will be back tomorrow early to get it done. I have no problem with their work ethic, it was just too much heat & not enough help.
They arrived on site this morning at about 7:30 AM. I pointed out the access point the concrete & gravel trucks used and they decided it would work for them as well.
Frame components were unloaded first and the bows assembled with braces.
Sill plates were placed all around, those on the sides have uprights for the legs to slide over.
Front & rear end gables got skinned and trimmed before going up.
After verifying slab dimensions & squareness, sill plates on the sides were fastened down to the slab at the outside points, then measured & trued at centers before they were then fastened to the slab.
Bows with legs got tipped up & placed on the sill plate uprights. Temporary knee braces would keep things plumb until the sheet metal skin was applied.
Because it is a vertical roof design, purlins were placed across the bows for roof metal attachment points. They had started screws on the bows at the purlin cross points so they would have a place to rest before getting screwed down.
Vertical members went in at the front to frame the garage doors. In the rear, they were placed equally.
At this point, they finished skinning in the building. This was accompanied by removal of the temporary knee braces. The lower portions of the front, around the doors, was done with partial sheets.
Framing for the windows was next. I choose to add 6 windows, 2 on each non-front wall. After seeing the hassle it is to frame them in, I understand why a 30" window is a $150 add on...
Once the framing is in place, the skin is cut around the perimeter. The skin is not secured to the frame as the window unit gets inserted between frame & skin, sitting on the frame member.
At this point, about 2:30PM, both were cramping up and in no shape to continue. They unloaded the materials needed for completion from the trailer and packed up scrap to carry out on the trailer. One guy & the trailer will go back to load for next week, the other will be back tomorrow with a truck & one or two more to help finish up.
That's it for this installment, hopefully tomorrow will bring closure to the build. There are still three windows to install, two garage doors, the roof, ridgeline and all the trim.
Nick
