The building is pretty full now. In addition to the stuff here already, we brought the 3038e back from the acreage along with the implements that had been in use over there (except the rotary cutter - that stayed there under shelter). The items brought back were 6' landscape blade, 6' landscape rake & 5' box blade.
I made dollies for all non-wheeled 3pt attachments (except middle buster & hiller) so they could be stored inside the building & be man-movable. The exception was the 6" Jimna PTO wood
chipper. That got "out-riggers" added to the 4x4 feet I had already added for better stability and PTO shaft alignment. The out-riggers had casters on the bottom that support the
chipper by about 1/2" when on concrete.
This is what has been loaded in to date:
Started out with the easy stuff, the finish mower, backhoe dolly & carryall w/generator (carryall has casters that give 1/2" clearance while on concrete).
The
chipper on its wheeled out-riggers.
Dollies were made for the PTO tiller & the post hole auger.
The box blade got a dollie & the backhoe is now on its as well.
I had to think a while about the landscape rake & blade. This is what I finally came up with. It is an "L" shape to take advantage of the ability to rotate the implement vs the lift arms. Making two the same would allow them to be nested without needing any more "depth" against a wall.
First the blade.
Then the rake.
Without crowding the 1025R on its side.
The 3038e is doing OK on its side, as well
The other thing I did was to add some 12v lighting. I picked up 4 27w 12v LED worklights (60 degree flood) and mouted two up high on the back wall & 2 on the front wall. The feed lines run down & are terminated in an anderson powerpole connector set between the two doors. I use these a lot on radios and accessories so most of the small SLA's around the place have a pigtail with these already. I grabbed a salvaged UPS 12v set and left it in the building in case I need some light ...
This pretty much sums up what has been going on with the building to date. The 22'x20' footprint now contains the following:
1025R w/FEL
3038e w/FEL
260 backhoe on dolly
59" finish mower
60" PTO tiller on dolly
6" Jinma PTO
chipper on casters
60" box blade on dolly
post hole auger on dolly
6' landscape blade on dolly
6' landscape rake on dolly
set of strap-on bucket forks
small wagon for 1025R 3pt hitch & sprayer storage.
All above are man-movable within the building so they can be brought to a door for attachment as needed.
Nick
