Rural Internet
   / Rural Internet #51
Are you sure the weed is medical and not for the Bruce?
   / Rural Internet
So I'm pulling this back up because I'm going to experiment a little with my Mofi. The unit that Ubifi sells is supposed to support Verizon, which is a bit faster at my place than AT&T. It looks like Verizon has an unlimited pre-paid plan for $70/mo but, it's going to be a little bit of a hassle to get it. I think I know what I need to do, buy a cheap Verizon hotspot, activate a SIM and them put it into the Mofi, so I'm going to give it a go and see what happens.
I also see an AT&T unlimited pre-paid plan for $30/mo, the only catch is it might get prioritized after 22GB. I've got a bunch of AT&T SIMs here to try that with as well. I'm not really sure whether I want faster or cheaper though. Anyway, I'm going to goof about with it and report back with my findings. It'll take a couple of months at Lea because I know I'm too cheap to waste data I've paid for. LOL
   / Rural Internet #54
I'm very very interested in the outcome of this experiment!
The best internet I can get without cellular at my house is a wifi internet at 3Mbps, and last I had it the quality was poor (many outages). I don't have anything remotely line-of-sight, no fiber or cable in the ground (with service I can have - a Gigabit fiber loop was installed a couple years ago on our road but it's not for mere mortals apparently) so I dropped it and lost my static ip with it... I survive off of cell phone hotspot.
I tried VZW's hotspot service, but at the time it was a lot of money for like 20GB/month which was laughable, we burned through it in less than two weeks then, and I can't imagine it lasting even a week now.
How "unlimited" is their service now? I have the family on an "unlimited" plan which gives 22GB/month per line with no throttling, and then they may get throttled if the "local tower is congested" past 22GB but we haven't seen that.
   / Rural Internet
It doesn't say anything about prioritization on this one. Of course, the only way to really know sometimes is to try it. Screenshot_20190116-185423.jpeg
   / Rural Internet
I got my $25 MiFi today so I was able to order a prepaid Verizon SIM for $65/mo unlimited with auto-pay setup, it should be here in a couple of days and I can see if it's as easy to switch the SIM into the Mofi as it looks like it will be.
Another thing I've noticed is that if I activate an AT&T SIM card on buyasession.att.com using the Mofi IMEI, my data plan options are $25/mo for 5GB or $360/yr for unlimited so, if the Verizon SIM doesn't work out, I can purchase the annual unlimited AT&T for $360 and drop from the $80/mo with Ubifi to $30/mo. There is nothing in the fine print on that one about prioritization or throttling after a certain threshold. (Plan and term screenshots below)
Verizon is 3x the speed of AT&T here though so, I'm hoping it works well, it's still $15/mo cheaper and I like fast better than cheap. That SIM will be here Monday so, I'll update then.
   / Rural Internet #57
I'm very interested in your experiment with the $70 unlimited Verizon account. I have better Verizon signal than AT&T is really the only reason, but if it saves $19/month as well, then may be well worth it. I'll be most curious to know if it has throttling or not as that would be the ultimate detractor.
   / Rural Internet
I got the Verizon SIM today, it took some trial and error to get it working correctly with the Mofi. Ultimately, these are the steps you need to follow:
1 - Put the SIM in the Verizon JetPack you used for an IMEI to order the SIM, power it up and connect. I think it needs this step for Verizon to verify the SIM went where it was supposed to.
2 - Insert the Verizon SIM into the Mofi and perform a factory reset on the device. When it reboots, it should detect the everything correctly and connect to the Internet. I setup a custom APN of vzwinternet. I'm posting a few images showing the signal strength, speed test result and my configuration for the Sierra card.
So now I find out if unlimited is truly UNLIMITED, I'll know within a week the way we go through data. Signal strength with from -105dBm on AT&T to -85dBm to -90dBm with Verizon and the speed test went from 8/3 to 26/21.
We're running on Verizon now, in fact I'm watching streaming TV and posting over it. I'll update in a week or so with our data usage and speed to see if we're getting prioritized.
   / Rural Internet
We've used 70GB since I switched to Verizon so I believe this really is UNLIMITED unlimited. I have noticed that carrier aggregation never gets assigned with Verizon but, I'm still running at 23Mbps or higher whenever I run a speed test so I don't really need it, it's faster without it than AT&T was with it.
RIGID 141 PIPE THREADER (A53843)
RIGID 141 PIPE...
MILLER MILLERMATIC 252 WITH SPOOL GUN (A53843)
MILLER MILLERMATIC...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
