Kioti Tractor Tuning
/ Kioti Tractor Tuning #1
BossTractor
Bronze Member
Parkland County, Alberta
2016 John Deere 3032E
So I did a little research into tuning Kioti tractors and found some information I'd like to share.
The CRD engines run a Delphi DCM3.7 ECU. I know RX and NX run this ecu. Possibly DK and CK as well. There's a sticker on the ECU that will say "DCM3.7"
The tuning device is made by alientech.
JTAG Renesas SH705x is the device needed
14P600KT02 is the cable (not a simple plug and play, involves opening ecu and soldering)
ECM titanium is the software
981 is the protocol
JTAG Renesas SH75x | Alientech Tuning Tools | Alientech Tuning
All the hardware and software is not cheap. But I'm sure some of the well known Ag tuning companies out there could tune these ECU's no problem. One European site claims they can achieve 90hp out of a RX7320.
This software can also turn off DPF and EGR systems for deleting them
/ Kioti Tractor Tuning #2
Do they have any dyno charts showing the different tunes that they have run?
/ Kioti Tractor Tuning #3
981 is the protocol
Kioti uses an adaptor to hook to the OBD2 connector to a PC laptop but it would be interesting if the same thing can be done with this scan tool容specially updating stupid stuff like injector codes.
Can the ECM soft ware run on a regular PC laptop?
Yes it runs on a laptop. It's similar to EFI live tuning and HP tuner. This isn't a scanner type device. You change fuel maps, timing, boost etc.
CC diesel performance & tuning messaged me back and said he can tune the kiotis. You can find him on Facebook. He's in Oakes, North Dakota and has a few dealers that upload his tunes across the US and Canada. A friend of mine runs similar tuning on his John deere s690 and 9520RX
No dyno charts for kiotis.
You really need charts to verify the results.
The hardware and software listed above works with over 6000 different vehicles. Around 200 different ECU's. Everything from motorcycles, atvs, trucks, cars, Ag tractors, and highway tractors.
The 17hp gain on the RX I saw on a different website. A company using this hardware and software. I'm not sure if they have dyno'd an RX. But any good tuner will know how to get 15hp out of a small Diesel engine from previous experience tuning similar engines. It's not a plug and play device like say a bully dog that you select a HP setting. They build a complete custom tune.
You go into fuel injection quantity, fuel timing, comanded TQ, commanded boost, etc tables and can increase the values.
For example the fuel injection table. On the upper rpm range you could increase the value 25%. Down just above idle 5%. Than everything in between a smooth gradient up to the 25% to give you a smooth power curve.
There's also maps that change the injection rate and power dependant on engine coolant temps, intake air temps, etc.
/ Kioti Tractor Tuning #7
I don't know.... More power is nice.... But at what cost?
And what about the longevity and durability of the machine?
These are unknown factors that someone would have to test.
Any volunteers??
/ Kioti Tractor Tuning #10
I would just like the get at the ECU for service.
From what you know, what would I need to get at Kioti for service and code reading?
/ Kioti Tractor Tuning #11
Any volunteers??
Parts for the 45-60hp are the same, the tune is different, so a change in the fuel map and maybe waste gate pressure, and poof, you have my 60hp machine. I'm fine with the power of my machine right now but i do need access to the codes and the ability to tell the ECU about new injectors.
Let's get r done...
I'm guessing you have to send the ECM to them and they do their thing.
I would need to see a guarantee with some kind of warranty on paper before I would do it.
Yes it's a bench top tune. Need to send ecu away. I'm looking into other options
/ Kioti Tractor Tuning #13
I want 80HP.... Damm it... At the PTO!
/ Kioti Tractor Tuning #14
After the warranty runs out on mine I would just like to be able to delete the DPF and EGR, the two things that seem to be the most troublesome on the Tier 4 diesels when they get older. Kioti claims that this is a 20K hour engine but I doubt that the DPF is.
Here's all the information I have dug up so far.
Daedong uses a Delphi DCM3.7 ECU for their engines
The Delphi DCM3.7 ECU has a Renesas SH705x micro controller that communicates to the EEPROM (electrically erasable programmable read-only memory) via 981 communication protocol
You can read/write to the EEPROM using a BDM (background debug module) bench top method. Basically you remove the back cover of the ECU. Place the ECU in a jig and use a module that is attached to the jig that has pins that you align with some diagnostic points on the ECU pcb and read/write to the EEPROM this way.
It is a rather common tuning method for vehicles not supported by a common OBD2 tuning software.
Once you get the information from the ECU it's just normal tuning, adjusting maps, turning off emission systems if you want.
I can't find any information regarding what communication protocol the diagnostic port uses to confirm if it is infact OBD2 and if a reader like a ELM327 would allow a person read codes.
/ Kioti Tractor Tuning #16
I'm wondering if a half-volt zenor diode soldered across the pressure sensor and a test tube installed in lace of the DPF would do the trick or if the ECU is smart enough to want to see a variable voltage comming back from the pressure differeial sensor. On page 12-77 of the service manual a 5 volt reference signal is sent out to the differential pressure sensor. Then:
"The differential pressure sensor detects the pressure difference between the inlet and outlet of the CCRT and sends a signal value of 0.5 to 4.5 V to the ECU. The larger the pressure difference between the inlet port and outlet port is, the closer the signal value gets to 4.5 V. The smaller the pressure difference is, the closer the signal value gets to 0.5 V."
The manual shows a picture of a DP5000 pressure sensor. I tried to unsuccessfully track this sensor down through Google, but it is the white wire that sends the signal (modified reference voltage) back to the ECU
Perhaps the internet can continue to puzzle this out frther.
And here a theretical way to build a circuit in place of the pressure sensor. Unfortunately, the Analog Behavioral Modeling is a little beyond my current skill-set.
Voltage-Controlled Resistor
I've also considered dropping in a digipot, but again, I don't know if the ECU is smart enough to kick into limp-home if it sees a constand signal or if the signal must have some variation.
http://www.analog.com/media/en/news...ection-guide/Choosing_the_Correct_Digipot.pdf
Anyway, my current high nail is just being able to interface with the ECU for service work, not modifying.
I don't believe a zenor diode would be the thing to use.
Pressure transducers typically output a voltage ranging from 0-5v. You would have to know the voltage output the sensor outputs for a clean filter then use a resistor to bypass the sensor and output the right voltage to the ECU. I don't own a Kioti yet so I can't go look at the DPF differential pressure sensor to see if it's two separate sensors or one with two inputs from the filter. If two inputs to one sensor you would have to determine if the sensor just outputs a value for the differential. Or two values for input and output pressure that the ECU then uses to calculate differential pressure.
/ Kioti Tractor Tuning #18
See the post above (lower right of manual page). It would be super easy to back-probe the white reference wire and determine the signal voltage right after a regen cycle. :)
/ Kioti Tractor Tuning #20
I say, run what have or get rid of it.
If you need to modify it, then obviously, it is not the right machine for you.
If you can make it a better machine, please forward the information to Kioti so they can correct it!
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
211297 (A62131)
211297 (A62131)
RAIN FLOW HOLE PUNCH, 3PT (A63291)
RAIN FLOW HOLE...
2006 Ford F-150 Ext. Cab Pickup Truck (A61573)
2006 Ford F-150...
ROUND BALE HAY RING (A63291)
ROUND BALE HAY...
