0.22 Cal Drive Pin vs. TapCon
   / 0.22 Cal Drive Pin vs. TapCon #11
Can't think I've ever had a tapcon fail on me
   / 0.22 Cal Drive Pin vs. TapCon #13
Not necessarily pertaining to anchoring shoe plates...but it is quite common for architects to specify certain length/size of Tapcons for a variety of concrete fastening applications in both commercial and residential construction.
I have also seen engineer specifications for secondary truss anchors to be secured to the vertical surface of concrete walls using Tapcons...This was common where there was no imbedded straps in a concrete lintel or tie beam...In these cases the possible lift forces put the fasteners in shear (rather than lift) where specified size/length easily met the load demand...
The one place I have seen the use of Tapcons rejected is anchoring shoe plates on exterior bearing walls where there was possible lift from wind loads etc...
2011 MERCEDES-BENZ S-Class Sedan (A55758)
2011 MERCEDES-BENZ...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
2019 FORD F-150 XL TRUCK (A51406)
2019 FORD F-150 XL...
UNUSED JCT HYD AUGER (A54757)
UNUSED JCT HYD...
2000 FORD F-350 SUPER DUTY BUCKET TRUCK (A52472)
2000 FORD F-350...
