'03 Ford F350 6.0 PSD Issues
   / '03 Ford F350 6.0 PSD Issues #11
The stock air filter on the 6.0 engine can be fickle to R/R. Make sure it is installed correctly & securely (no air leaks). Check all nearby wiring,sensors, etc. just in case something was knocked loose.
You can also go to your local auto parts dealer and run a scan with their OBD ll test unit. Most will let you use it for free in their lot. Just hook it up to the serial port and follow the onscreen instructions. Write the codes down that it reads. Then go home and do a search on your computer using the code numbers you pulled... such as Ford Pxxxx. You will then have an idea of what needs to be done.
After the fix, you can clear all the codes by disconnecting all batteries for about 30 minutes or use their OBD ll tester to clear the codes.
   / '03 Ford F350 6.0 PSD Issues #12
I have an 04 F-250 with a 6.0 diesel that is completely bone stock. Yesterday, I drove from Tacoma, WA to south of Portland, Ore and back to retrieve a CK-35 Kioti tractor, loader, backhoe, and brushhog. The stock 6.0 had no problem pulling the trailered tractor with extras up hills doing well over 75 mph with plenty of pedal left.
Same here, I just made a trip into NE GA from central FL to grab a tractor, before that, went to lousiana for one, and my previous trip was a 40 hr red eye into central texas. all pulling a 16' trailer empty one way, and laoded with a tractor the other. absolutely no power issues at all. Made the trip a whole lot better than my dodge 5.9l gasser would have.
soundguy
Well guys here's an update. I've been reading on the web and am seriously considering changing out the ICP sensor and maybe the pigtail connector. These will probably run in the $175-275 range depending if I need one or both. Problem is my year model and the location of the sensor. It's on the DS of the engine at the back behind several parts. Some say go from on top and take parts off to get to it and some say go from the bottom and reach up. One other thing is I'm debating going ahead and putting it in the shop to have the "Inductive Heating Reprogram" done. I'll have that charge anyway but thought I'd save the other and do it myself and hope this does the trick...Comments?...:confused::eek:
   / '03 Ford F350 6.0 PSD Issues #14
With as much as these trucks cost and how complicated they are I would let the Ford Shop do the work. Sounds like it has been a good trouble free truck for you up to this point. Taking a 7 year old truck to the shop only makes since and have it checked over. Spend a little money on it and it will last you a long time. Heck, it may still be under warranty and like I said there were many service bulletins on the early 6.0's like you have and it may be covered under warranty.
Chris
Chris
You know Chris, just yesterday I was wondering the same thing as I read some info on the web. I'm not the original owner and Ford doesn't have me and my address on record as the owner of this truck. I might have missed out on some information they would have sent out. But I guess that would only include recall stuff..? Not service updates and all. What do you think?:confused:
   / '03 Ford F350 6.0 PSD Issues #16
Take it to the dealer and pay them to check it out. Talk to them first and set a cap in $$$ on the work they can do. My local Ford Garage will do a oil change, rotate, check all lights ect, run it on the computer, and check the vin for outstanding stuff for something like $50. It will cost more for a Diesel but talk to them. We did this on a Navigator my buddy bought of the net. Good piece of mind and worked as a pre purchase inspection for him. They even took us in the shop while it was on the lift so we could look it over.
Chris
Ok. Here's the skinny. I took my truck to local Ford dealer and here's what they're telling me. When the truck is cold the injectors are "dropping out". SOOOOO, they want to put a new ICP sensor on it, a new high pressure pump and EIGHT, yes I said EIGHT (reman) injectors in it so thats- 169.50+336.30+8@312.32=3004.36+1600 labor and 255.37 for big brother and that's a grand total of $4859.73:confused2::confused2::mad::mad:
Needless to say I paid my $149.95 for the diagnostics and left. Well not exactly that way but I'll be nice now.
What do you think for a truck with 78000 miles, yes, that's seventy-eight thousand not 7 hundred and eighty thousand?!
   / '03 Ford F350 6.0 PSD Issues #18
About the same issue with my neighbors 2007 Duramax with 45,000 miles. They want $1400 to change just 2 injectors.
I would have them start by putting on the ICP sensor, resetting the computer and give it a try.
I may have them also change the pump if they can prove its faulty but probably would just try the ICP first. You can always bring it back.
These things are expensive. I can not believe it needs all that. I would take it somewhere else and get a second opinion.
Chris
Chris
Chris, that's exactly what I'm going to do. I only took it to Ford to take advantage of any "factory updates" and whatever they might have on it. I've got a good garage that I usually take my trucks to have the heavy stuff done at. I'm scheduled to take it there on Monday.
   / '03 Ford F350 6.0 PSD Issues #20
Sounds like you need a second opinion. I am not a factory trained Ford Tech, however I am an ASE certified master truck tech with 14 years of Diesel fleet experience. Most of the time, the high pressure pumps are replaced due to leakage of engine oil from the pump into the valley of the engine, and down the bell housing to the ground. This is often mis diagnosed as leaking valve covers. In the beginning, this leak is just annoying, but as time goes on, it will turn into a rough running after a cold start due to air entering the High Pressure oil system, then as more time passes be accompanied by excessively long cranking times, combined with rough running for the first few minutes of run time until the air bleeds out. These are all signs that the HP pump is on its way out. Shine a flashlight down into the engine valley in the very front of the engine between the cylinder heads, Do you see any oil puddles in the valley ?.
I normaly access the ICP from the top, but to each his own. In my experience, HP pump failures are more common than ICP failures. What codes were retreived from the truck, what did the dealer say the HP pump oil pressure was during cranking, idling, and high boost.
I just tore down a 2002 7.3 today at work to replace the HP pump. It currently is torn down in my bay, if you would like, I could take some pics of the old and new pump, as well as where it is at. I realize it is a 7.3, not a 6.0, but it might give you a better idea of what you are looking at.
2006 Caterpillar 315C L Hydraulic Excavator (A56857)
2006 Caterpillar...
2015 Freightliner M2 106 AWD Terex Commander 4047 Digger Derrick Truck (A55973)
2015 Freightliner...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
(2) OIL DRUMS & PUMP (A58374)
(2) OIL DRUMS &...
2023 Bobcat T770 (A53317)
2023 Bobcat T770...
