08 CT230/CK30 leak at block and tranny
   / 08 CT230/CK30 leak at block and tranny #1
Toddinmn
Dayton
None
ATTACH=CONFIG]654054[/ATTACH] ct230.jpeg
Long time lurker first time poster. It is leaking right behind the hose clamp and below the dental pick where I think the engine and tranny meet. There is a big gap on the block side that appears to be a casting flaw perhaps. Has anyone else seen or had this problem or have any solutions? The leak turns to a spray when running.
   / 08 CT230/CK30 leak at block and tranny #2
Hello! You've verified the spray is coming from the gap? BTW, not entirely sure which gap you're talking about. Can you circle it or point it out a bit better on the picture? Hydraulic fluid or engine oil?
I think any casting flaw would have presented an issue long before now. If fluid just started spraying, it's probably because either a seal gave out or something broke.
   / 08 CT230/CK30 leak at block and tranny #3
Definitely hyd fluid probably coming from one of those lines. Where is this located on the tractor? Need a better picture if we are going to help.
The leak is hydraulic fluid. It is coming from where the arrow is in the picture where the gap is between the block and the tranny.
   / 08 CT230/CK30 leak at block and tranny #5
Can you maybe pull back and get more of a macro shot? Maybe a video posted on YouTube or something? Hard to tell what it could go to. Regardless, it's likely broken or has come free somehow.
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
UNUSED GAS CADDY (A54757)
UNUSED GAS CADDY...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55218)
2003 International...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
UNUSED (1) 3500# AXLE W/ BRAKES (A54756)
UNUSED (1) 3500#...
