1/4-18 thread machine screw?
   / 1/4-18 thread machine screw? #31
It's almost as if someone set up a screw machine wrong. Had 1/4" stock and 18 thread per inch cutters just adjusted them until they made threads?????
I've been watching this to see if the mystery is solved.
Kinda what I was thinking at first as well. Someone made some screws and did it wrong.
But...How did they tap the holes???
Mystery indeed
   / 1/4-18 thread machine screw? #33
not solved yet. i've sugested going 5/16-18 with a tap. it's the least invasive i think.
   / 1/4-18 thread machine screw? #34
That would "yield" you a 1/4-18!
Well, :confused3: it would neck down a little - but close enuf. ... Actually, tapping to 1/4-20 should be plenty strong since the nut has greater thread root and thus its threads have inherent strength advantage over those on the bolt.
And heel be able to use either bolt. :D.
   / 1/4-18 thread machine screw? #35
base material is aluminum.. have to take that into consideration as well.
   / 1/4-18 thread machine screw? #36
A weaker nut metal would make some difference, but i didnt see it stated.
larry
   / 1/4-18 thread machine screw? #37
At this point, I'd think one of THESE
Amazon.com: ramset
Would be lookin' pretty good.. :thumbsup: Steve
And yes, I'm kidding...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2018 FREIGHTLINER...
2015 KENWORTH T680 SLEEPER (A59575)
2015 KENWORTH T680...
KBH Tender Trailer (A56436)
KBH Tender Trailer...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A56436)
Michelin CARGOXBIB...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
