ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 32,246
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
RobertN said:I found one that drives me bonkers. Our fire station has a GMC Topkick with a Detroit 8V and a 10spd Road Ranger, carrying 2800 gallons of water plus fire equipment. Most of the time, that thing drives me nuts. Just something about the Detroit and that 10 spd. I'll get through a few gears, and lose it. Can't catch a gear for the life of me.
I drove an old buddies Freightliner 10 wheel dump with the same tranny mated to a Cummins. Did just fine. Got back on that water tender, and missed gears, had to stop and start from 1st.
I'll sound like some weird, guru, spiritual twirp here. It's all about being one with the vehicle. Completely understanding the relationship with rpms, ground speed and desired result. When you are in neutral and lost, your salvage is in your right foot and an understanding of what I just said. Make a decision about what gear you desire to be in and adjust the rpms accordingly as you gently apply pressure to the shift lever and it will slide right in there. When you see those guys smoothly going thru shift changes while consistantly gaining speed they are "one with the vehicle". As I said earlier, it's a beautiful site.
When you see a "cowboy" jamming gears and jerking the throttle causing the truck to lunge, belch smoke, make noise and generally hop along it's sinful and there should be a law!!!! When you look around to see a truck making all kinds of noise and doing that, you are not witnessing a truck driver, you are witnessing a cowboy!!!
