10 ga wiring question
   / 10 ga wiring question #11
Welders are allowed to use under sized wire given the duty cycle. They arent drawing current constantly.
Sizing wires is all based on how hot the wire is going to get. And using a welder, even undersized wire isnt going to get that hot based on the time it is used in a given hour.
From my understanding (Im no certified electrician), but 220v circuits (if there are also 110v circuits involved) require 4 wire setup. Like a range, or dryer, which has heating elements that operate off of 220v, but control circuits that run off of 110. Those need 4 wire. For loads that are 220v only, like shop equipment, air compressor, water heaters, etc. Only 3 wires is required. 2-hot and 1 ground.
So if you use the romex, 10-2 will certainly work for temporary cord. But going to 10-3 SO cord will be better long term.
Also, When talking about romex and 10-2 and 10-3, the 2 and 3 are the number of current carrying conductors. Not the total numberof wires. So 10-2 romex will have a black, white, and a bare ground. With SO or SJ cord, You would need 10-3 to get the proper number of wires. Since the ground in them is insulated and not bare, it is counted when talking about 10-2 and 10-3.
Thanks for the explanation LD. I know how many wires are in each just because I counted them over the years but I did not understand why.
Not sure how this welder does the transition from 120-240 but I have to plug it into a 120v outlet to use the 120 side and I have to plug it into a 240 v outlet to use the 240 side. It has 2 different ends to stick on the wire and it knows what it is plugged into. And they are both 3 prong plugs.
New Kivel Mini Skidloader Pallet Forks (A50775)
New Kivel Mini...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2015 UTILITY VS2RA...
9000 (A47477)
9000 (A47477)
2019 Dodge Grand Caravan SXT Van (A55853)
2019 Dodge Grand...
2025 20-Drawer Workbench Toolbox (A55788)
2025 20-Drawer...
1999 Ford F-450 Mason Dump Truck (A55788)
1999 Ford F-450...
