Depends on the tractor. The OP is talking about a 100 HP tractor which (in the busy seasons on a farm) probbaly gets used 12-18 hours per day. For a CUT such as your TC33, yes, I can see 6 hours or less per day, but I dont know if I would buy one as when we are working that many hours, we are trying to get hay in (usually before it rains) and we cant afford to wait for a battery to charge.
Aaron Z
Aaron, you're right, my ten hours is low when time is tight and weather is threatening.
I have no idea where I got this idea, but shouldn't a tractor's fuel tank be sized for a "full day's work"?
I don't see replaceable plug and play power cartridges until Buck Rogers arrives.
And no one, but no one, is going to wait for something to recharge in the middle of the day.
so yes, it has to last for a longer day.
I'm carefully researching ditching my gas outboard and changing it out for a German Torqueedo outboard.
so I've been studying range, and it sure is a tradeoff. Use half power and last a long time. Use all the hp in the motor
and that fuel meter will go down like an old Chevy gas gauge past half tank, zoom.
Plowing, discing, baling hay, all sucks a lot of hp. I can see the friendly neighbor coming out to help his buddy in the field,
with a D battery and a smile...
True EV may not make sense, like in a car. Need a gen onboard.
Ok. Ratchet this down to a JD 4720 or my
L5740, two well known compact tractors.
Now size really becomes an issue.
I still like my idea of a battery pack one can pull behind, like the coal tender on a steam train...
Or maybe use them to weight down the discs! Worlds most expensive concrete blocks.
