100 pound LPG tank....what to do? (out of date)
   / 100 pound LPG tank....what to do? (out of date) #11
Build a large Zen garden cut them at different heights and have different gongs around.... 😁
   / 100 pound LPG tank....what to do? (out of date) #12
If it hasn't been an issue with getting them filled, don't worry about it. My two forklift tanks are waaaay out of date and I've had no problems.
I could see it being an issue if you went to a distributor, or had them filled on site, as that could be a cya issue for them if something went pear shaped, but just going to Corner Gas where they have a propane station in the back corner, they probably don't even know about certifications.
I am rather surprised to hear that some distributors will fill 40 yo tanks, but that could be regional, long time good customer relationship, lots of factors.
   / 100 pound LPG tank....what to do? (out of date) #13
A good propane company will take out the valve, put a new one in, pressure test it, and then fill it. Then they stamp a good through date on it.
The tank is still just fine, it's the valve they replace.
   / 100 pound LPG tank....what to do? (out of date) #14
I have a 100 lb bottle that I use as an air tank. You can get 4, 15" tires to 20lbs with one full bottle. You can also run a 3/8" impact wrench or a die grinder long enough to finish most jobs. I've also used it as a surge tank at the end of a long run of air hose. It lets you keep using the air nailer till the compressor has a chance to catch up.
   / 100 pound LPG tank....what to do? (out of date) #15
I bet they can be re-certified. A quick google search says 12 years after the manufacturing date and every 5 years after that. I would call a local propane company and ask. I bet it's a simple process.
And a LOT cheaper than replacing... even for a 100# tank. Mine have been recertified a number of times. I think it was a $15 charge, which basically was looking it over and slapping a new sticker on it.
   / 100 pound LPG tank....what to do? (out of date) #16
^This.
No different than the big propane tanks. I changed propane suppliers a couple years ago so I got a "new" tank. Turns out the guy who delivered the tank I used to work with out at the mines some years ago. I noted to him that my "new" tank was built in 1979 according to the attached tag. He told me that propane tanks do not age out. As long as it is undamaged (no excessive rust, no dents) then they put in new valves, pressure test it, paint it and put it back in use, no matter how old it is.
   / 100 pound LPG tank....what to do? (out of date) #17
Only portable tanks have to be DOT certified. I don't think 100 lb. tanks are considered portable.
   / 100 pound LPG tank....what to do? (out of date) #18
If it's shot (too badly damaged/corroded to hold pressure), you could probably make a decent forge from it if you want something for blacksmithing/knife making/general heating up of metal you'll bang on. Key is once you unscrew the valve, fill it with water before you start cutting on it. Might also make a small smoker if you don't want to do the blacksmith thing.
2 MONITORS:  HP & SAMSUNG (A53843)
2 MONITORS: HP &...
2013 Dragon Double Rail Roll Off Trailer (A53117)
2013 Dragon Double...
2015 VOLVO L90H WHEEL LOADER (A52705)
2015 VOLVO L90H...
Genie GTH-644 (A50490)
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
