$1000 Coolant Change Part 2 The Answer
   / $1000 Coolant Change Part 2 The Answer #41
   / $1000 Coolant Change Part 2 The Answer #42
Here is only other thing that could possibly, although much less likely, be
the cause of all of this as well. Electrolysis can also cause the metal to
be attacked, while keeping degradation acids low. If there is a poor
electrical system ground somewhere and the coolant becomes conductive, then
this type of aluminum corrosion will not take long to occur. I'm sure the
dealer may have checked this, or if not it would be helpful to eliminate
the possibility. Any reading over .2 volts in the coolant cause be
considered harmful.
This one is easy to check and I do it regularly on all my vehicles. If you are not familiar with the process here's how to do it. Using a quality VOM set on DC Volts, place one probe in the coolant while NOT touching any part of the radiator. Touch the other probe to the negative battery post. If it reads more than .2 Volts, you have a problem.
   / $1000 Coolant Change Part 2 The Answer #43
   / $1000 Coolant Change Part 2 The Answer #44
Yeah, after reading this thread I think I'll stop drinking Perrier and put it in my tractor.
May not be a good idea as Perrier is mineral water with 500PPM of total dissolved solids. i.e. moderately hard water.
There are two kinds of electrolysis:
1. Due to a faulty ground.
2. Due to different metals.
If you have .2 v or above, disconnect battery and measure again. If the voltage is gone then you have #1 above. If it is present you
have #2.
It may take 1-2 minutes for your digital meter to final come to a steady reading. Many auto manufacture say anything below 0.3v is acceptable.
I have a weak type 2 electrolysis but under 0.1 v and goes away when battery is disconnected. Be sure to use a DIGITAL METER.
   / $1000 Coolant Change Part 2 The Answer #46
Just remove the rad altogether.:p
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
JOHN DEERE 8R310 TRACTOR (A54756)
JOHN DEERE 8R310...
Etnyre 2000 Gal Asphalt Dist. Truck (A47477)
Etnyre 2000 Gal...
2019 FREIGHTLINER CASCADIA TANDEM SLEEPER TRUCK (A54607)
2019 FREIGHTLINER...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
Two Post Car Lift (A50120)
Two Post Car Lift...
