FredH
Platinum Member
The 68 RFE is the transmission I rebuilt and while " Yes " you can beef them up , there are more clutch plates , planetary assemblies that are billet grade , etc.. . There are a couple of key area's that have no upgrades available . One of the main downfalls is the thrust bearings . When 1 fails , the transmission is on borrowed time . There are like 9 or 10 in a kit , spread through out the transmission . Another is the end shaft play adjustment . This is made by various thickness plastic disks . You start with what thickness came out of the transmission , Assemble Transmission to point you can check end play and hope it is right . Otherwise , pull apart and go thicker or thinner . The problem is the disk itself .
We looked at the $5000+ custom rebuilt's , All had the same thrust washers and thrust bearings . I am not knocking any one who is into that kind of power , what ever floats their boat . I use to love going to the diesel bulletin boards and reading the stories and their questions on " Why " it happened . I am a practical type , If it works as is , Don't mess with it .
Fred H.
Fred H.
