1000 rpm pump run on 540 rpm
   / 1000 rpm pump run on 540 rpm #1
desert trader
Shoshone,Idaho
Massey Ferguson 165
Can a 1000 rpm pto pump that puts out 23 gpm 2200 psi be run on a 540 rpm tractor and if so what would it do to the gpm and the pressure out put.
   / 1000 rpm pump run on 540 rpm #2
Output pressure is determined by relief valve setting and applied load. Pressure will not be affected by operating a sound pump at approximately half speed. Flow from fixed displacement pumps is speed dependent. GPM will be approximately 12.25.
   / 1000 rpm pump run on 540 rpm #3
Yup, as Rick wrote...pressure is constant, GPM will be affected.
Hey thanks alot for the info you just might have saved me a lot of money.
It's great to have a place to get must needed info,thanks again.
   / 1000 rpm pump run on 540 rpm #5
As said above... You will however need to keep the rpms up for good pump performance. 1/2 speed is barely a problem, but idling down on the already reduced pump speed will have it running at 1/3 or 1/4 speed. As the oil thins with warming, internal pump leakage [proportional to output pressure, but independent of rpm - and increasing as the pump wears] will start to overtake output. For example ... In a fully warmed system running at full pressure at 1/4 pump nominal speed it is likely you will only get 1/8 of nominal full rated rpm flow. Maybe less. At 1/2 pump speed youre pretty good - instead of the 50% capacity you will get around 40% at pressure. Not too bad.
Also, some types of pump are better than others for reduced speed service because they have less internal leakage. I have assumed it is a gear pump.
larry
   / 1000 rpm pump run on 540 rpm #7
Is this a pump you have, or thinking about getting. That pump requires about 34 HP to run it at a 1000 rpm.
I should be okay I have MF 165,I'll just have to get a pto shaft adapter.
   / 1000 rpm pump run on 540 rpm #9
Hes running it at 540/600. Less than 20HP.
larry
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
