1010 positive ground
   / 1010 positive ground #11
OK... I re-read the OP.
I just could not imagine 'butting up' one vehicle to the other in order to hook up the jumper cables.
I once saw a guy try to jump start a car with only one jumper cable. He hooked the cable between positives on the batteries. Both cars had metal bumpers so he made the bumpers touch to connect the grounds. For whatever reason, it didn't work.
   / 1010 positive ground #12
I have a 1010 that is now 12v negative ground, has electronic ignition (Petronix), and a Delco alternator. Starts every time and runs well. It was worth the effort to change.
   / 1010 positive ground #13
It's a lot of expense and trouble to convert to alternator and negative ground. If your generator is working, I would leave it as is. It's a solid design - nothing wrong with the factory design, and changing/setting points every few years isn't that much work.
I agree. That old design has a generator & voltage regulator to charge the battery. The only thing that differs from standard practice in most machinery is that it is positive ground. It was and is an excellent system. Very durable, parts are cheap, and it can be refurbished by most any mechanic with a few wrenches in a home shop.
There is no problem with positive ground - except you have to remember which way it goes if you replace the battery. The reason for positive ground is that it was thought at the time that corrosion on the battery cables would be reduced by using a positive ground. On mine, that seems to be true.
BTW, when generators and voltage regulators are new, they are rarely polarized. After installing them but before doing the final wiring or running them the field coils in each are "flash polarized" which sets their initial polarity to either positive or negative ground. After that, they are good to go. All you are doing with flash polarization is setting the initial north/south polarity for the residual magnetism of the iron core inside the field coils to match your battery. That residual magnetism is the "boot strap" which allows the generator to begin generating current with polarity to match the battery when it first starts to turn.
As far as the ignition goes....same thing. The originals last for decades or longer. And they are cheap to replace. The original coil, points, condensor, distributor cap, and spark wires can all be replaced in a few moments for pocket change. Another advantage is that system is easy to diagnose. You can actually see it working. Nothing in the ignition is polarity sensitive. It does not need to be polarized.
Electronic ignition would probably be a step backwards.....
good luck.
rScotty
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
Walking Floor Trailer (A50322)
Walking Floor...
2010 KENWORTH T270 SERVICE TRUCK (A51243)
2010 KENWORTH T270...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
