1010 Single row crop , clutch stopped working
   / 1010 Single row crop , clutch stopped working #1
1010RS12151
Glenmoore , Pa.
JD 1010 rs
Hi, just joined , hoping someone may be able to help , thanks in advance.....
Clutch will not engage engine or pto gears.Worked fine , parked it , now have the problem. Anyone run into this or have ideas.I adjusted the clutch but doesn"t make a difference. Didn"t feel or hear anything during use prior to parking it.It may have sat for a week before trying to use it and finding this problem. Very strange. Any help or suggestions , much appreciated!
Stuck dis-engaged ? Usually they stick engaged.
I park it out of gear and drop the blade , works well as a stop.I was hoping it isn't a worn clutch , but I'm leaning more that way.Once I drain the trans fluid I'll find out depending on what's in it.
