1020 - 3 point lift is jerky
   / 1020 - 3 point lift is jerky
The answer to that question is not in our crystal ball.. sorry.
But would you do the work yourself? whatever it might be?
Yeah...I know. Just trying to get a feel for how much it would cost IF something crazy happened (like the pump going out totally). I can do a little of the work but I certainly couldn't split the thing if needed.
Maybe it's best to just keep looking...
   / 1020 - 3 point lift is jerky #12
Does the tractor have any rear remote hydraulic connectors? If so, I would at least want to see standby pressure TxJim suggested. You need a male quick coupler connected to pressure gauge.
The 3pt should lift about 2000lbs.
I would worry more about the clutch than a jerky 3pt. That would require a split to fix.
I would probably buy it. Drain the hydraulic fluid (save it, since clean) replace the filter and clean the sump screen and refill. I doubt it's the pump. I think TxJim will tell many good pumps have been replaced when they were not the problem.
If you can get $500 off that would more than cover a filter change and even new fluid (takes about 10 gallons).
At first I told the seller "no"...but I then called some dealers and got feedback that it probably wouldn't be THAT major of a repair...so I pulled the trigger. Seller did agree to take $300 off the asking price.
Once I got it home I was able to take a better look. It may sound silly but it was hard to accurately see the fluid level on the trans fluid dipstick. It actually was several gallons low. I filled it and it seemed to take care of the issue. Then I used it for about 4 hours straight working my driveway and doing a little mowing. Once it warmed up, though, the lift got slow and started jerking a little bit again.
I'll change the filter and clean the sump screen at some point. It still works, just not 100%. Good enough for now.
I think I made the right choice. My neighbor came over and was surprised when I told him it was a 1967 model...said he would have never guessed it was that old by looking at it. Admittedly it does have some "character" LOL...but nothing that a can of JD green paint wouldn't fix. And, given the overall condition, the price was really good based on comparables that I had seen. Like I said, I used it for several hours and everything else worked great - loved the power steering and good brakes after dealing with my old MF50 for the last several years!
Thanks to all for the input/opinions.
   / 1020 - 3 point lift is jerky #14
If the shift boots are cracked or porous, they will let water in if outside in rain snow. Water will destroy the brake linings very quickly. I would do the flush filter change and sump screen cleaning NOW. Use the $300 you got off, you will have $$$ left over if you do the work yourself. Buy new shift boots if they look bad at all.
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
2006 TerraGator 8104 (A53473)
2006 TerraGator...
CAT 257D (A50123)
CAT 257D (A50123)
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
Serco 270 Log Loader (A52384)
Serco 270 Log...
2002 Freightliner FL70 Elgin Street Sweeper Truck (A51692)
2002 Freightliner...
