1070 JD - Replaced Battery, won't crank
   / 1070 JD - Replaced Battery, won't crank #11
Thanks for the come-back on that CB,.....could you be more specific on the switch fuse. Not sure what that would be from here. Suppose it could happen to any of us, and might be nice to be able to go directly to it? Does that mean the old battery was ok or was it fried anyway?
Sorry to put you on the spot there, but I really can't picture where that switch is,...unless praps it is the "seat switch" or one of the "shut-down" switches,...Please help.
Also,...the fuse must have blown AFTER you put the new battery in,...otherwise howcome it was starting when you were boosting it? Anyway I am confused!
Thank you
. . tug
Hi,
The fuse is in the fuse box on the right rear side. It is marked switch, 4 amp, purple. Replaced it, turned switch on, got that big click, them turned to crank, yea baby - first time.
Thanks CB
   / 1070 JD - Replaced Battery, won't crank #13
OK CB Thanks. Glad you finally located the problem and got her going.
CHEERS,
. . tug
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55301)
2023 NEW HOLLAND...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
UNUSED Artificial Turf Grass (A53117)
UNUSED Artificial...
