108 Year Old Hydraulic Cider Press Help
   / 108 Year Old Hydraulic Cider Press Help #31
I now have the spool "tee'ed" into the tank from one of the work ports. It now works up and down. I still want to slow the cylinder down, but the flow control valve i have bought, doesn't seem to so anything. I have reversed it and it will slow down the cylinder as it descends, but not as it goes up. Thoughts?
What type of flow control do you have? Since this is a fixed displacement vane pump you MUST have the relief before the flow control. If you install the flow control between the valve and cylinder it will effect the lower speed.
Do you have the V10 vane pump model code. If yes it will provide the flow rate of that pump.
   / 108 Year Old Hydraulic Cider Press Help #32
Does the juice flow over the cylinder? If so I would consider a food safe fluid. ISZ
Ok, so the V10 Vickers pump puts out 1 GPM as far as flow rate.
It took a while to track down and 'in stock' single acting control spool. I have it now and I am going to plumb it this week with new black pipe and fittings.
I will report once that happens.
2017 Mack Pinnacle CHU613 Day Cab Truck Tractor (A53117)
2017 Mack Pinnacle...
2005 National RV Inc. Dolphin LX RV (A53117)
2005 National RV...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
