10A Relay Fuse
   / 10A Relay Fuse #1
SpaceBuckaroo
Keokuk, Iowa
LS
Today the 10A Relay Fuse blew on my R4041H. I changed it and everything seemed to be okay, and then it blew again. Does anyone have a schematic of this circuit?
   / 10A Relay Fuse
Okay, I finally figured out what was causing my 10A fuse problem.
A couple months ago, I replaced my seat with a fancy, but cheap seat off Amazon.com. The seat is cheap, but I like it because it has a lot of travel in the bounce when I hit hard bumps.
Anyhow, the seat was cheap, along with the built in safety switch. The safety switch was crap. It would cut power off several times even when I was sitting on the seat. I eventually disconnected the safety switch and put a little jumper across the connector. That worked great for a couple weeks, but the jumper would sometimes slip and I'd loose power again.
Yesterday, I was working hard and it cut out again, I got pissed and cut the connector off, and twisted the wires together, and just let them lay next to the seat.
What I didn't know, was that today, while bouncing around, the wire shorted to ground and caused the 10A fuse to blow.
After posting asking for a schematic, it occurred to me to inspect the wires that I twisted together, and sure enough I could see where the wires were burnt along with some insulation. A little shrink wrap and that problem is now fixed.
   / 10A Relay Fuse #4
Hey, you can't say that word. I got a 30-day suspension for a similar phrase.
I was told there's too many children reading the Tractor Forum. 😏
   / 10A Relay Fuse #5
^^^ Weird ... I guess the kids are supposed to feel safe all the time? A switch would indicate that they might face something unsafe in life?
   / 10A Relay Fuse #6
It must ok for some and not others.
DITCH WITCH R300 STAND ON TRENCHER (A51242)
DITCH WITCH R300...
Quick Attach Hydro Slide Pallet Forks (A50514)
Quick Attach Hydro...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
VOLVO L45G WHEEL LOADER (A51242)
VOLVO L45G WHEEL...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
