the old grind
Elite Member
- Joined
- Jul 21, 2012
- Messages
- 4,406
- Location
- Mid-Michigan
- Tractor
- NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
I'm guessing that the 29cfm model is rated there at higher than 125psi, so my thought is that the smaller motor would suffice with that shut-off setting. RPCs aren't as flexible as VFDs, and Phase Perfect, while versatile, is to pricey for most of us.
PSC (permanent split capacitor) motors are often rated 'compressor' duty. Which means their hp rating isn't for continuous running. A 3hp is then 2hp if run continuouslyw/o o'heating, but can be overloaded and draw more current late & short in the pumping cycle, when pressure and amp draw peak. 5 hp 'compressor duty' is more like 3 hp continuous. If we load and dyno test these at their 'rated' hp long enough they will o'heat and should shut down by internal o'load sensor.
A continuous 5hp motor (preferably TEFC vs ODP, and CSIR or cap start induction run will last longer) The ODP 5hp HFT 1-PH that draws 15a. is a 5/3 compressor motor, the Baldor that draws 24a. is a real 5hp/
CSCR (cap start cap run) are vulnerable to either (say 180-210 mfd start, 30 mfd run in 5hp) cap 'deforming' if it sits long enough. We 'reform' any caps by charging them at lower voltages and or lower current to reattach gel-like chemicals to the foil layers within. Loading-up and starting a shelf queen can pop 'em without an hour or two of no load running.
I wonder if a 7.5hp, with that small tank and low pressure will run all your gear, even with a lighter duty (less costly) ODP CSCR motor. Your load doesn't seem to me to justify more power within those confines.
As Mendonsy says
thumbsup
look on ebay or CL for used motors, and good luck having much selection in 1-PH >5hp. I just 'searched' Amazon and ebay .. guess what "7.5 hp single phase" in the search box gets you 1/2 hp - >10 hp and 3 PH as well on any site, so don't count on the quickest 'find'.
If new:
New Leeson Electric Motor 7.5hp 1ph 23Volt 184T 345 rpm 1 1/8 shaft - 13244 - Compressor motor by Leeson - - Amazon.com
7.5HP Farm Duty Single Phase Motor 1 3/8" Shaft, 23/46V, 213T, 345 RPM, TEFC | eBay
Tell you what, if you rue my advice here down the road, I could drive down and buy the one you wish you hadn't.
<Meanwhile, if you have a 1-PH 5 hp to try, I'd gear it like you would the 7.5/29cfm (>90% the rpm of it), and see what amps it draws up to the 125 psi shut-off. t o g
As Mendonsy says
If new:
