10w-30 diesel oil
   / 10w-30 diesel oil #11
THe 10W30 for Kubota is actually not needed. The newer Kubota manuals states a 15W40 is just fine. I called Kubota and that's what they told me anyway.
   / 10w-30 diesel oil #12
</font><font color="blue" class="small">( THe 10W30 for Kubota is actually not needed. The newer Kubota manuals states a 15W40 is just fine. I called Kubota and that's what they told me anyway. )</font>
My manual lists 10W-30 or 10W-40, but not 15W-40 - though I'm confident there's not enough difference between 10W-40 and 15W-40 to make any discernible difference. /forums/images/graemlins/smile.gif
However, if I'm running my tractor in the winter, I figure I might as well get the lightest weight I can that meets the SAE specs. And, if it's hot enough in the summer that 30 weight isn't going to get the job done, I'm not going to be on the tractor anyway, until it cools down some. /forums/images/graemlins/grin.gif
So, if I can find the 10W-30 without a special trip, I'll use it. But if 15W-40 is what's available, I wouldn't hestitate to use that either. /forums/images/graemlins/smile.gif
   / 10w-30 diesel oil #13
The 90 SAE in the front axle is the one I worry about in the winter. I'm planning on running a 75W90 in the front after the 50 hr point.
   / 10w-30 diesel oil #14
</font><font color="blue" class="small">( The 90 SAE in the front axle is the one I worry about in the winter. I'm planning on running a 75W90 in the front after the 50 hr point. )</font>
Why not just run the super UDT in the front axle?
   / 10w-30 diesel oil #15
I have been running Amsoil series 75w90 in my front diff since 2002. Works fine.
   / 10w-30 diesel oil #16
You can use either one but I like the gear fluid.
Kawasaki NR (A50324)
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
Concrete pump (A52377)
2015 Chevrolet Silverado 1500 Pickup Truck 4X4 (A53473)
2015 Chevrolet...
NEW 24ft Feed Bunk Wagon (A55218)
NEW 24ft Feed Bunk...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
