110TLB Front Loader Mount Brush Hog
   / 110TLB Front Loader Mount Brush Hog #11
Yes. Thats exactly what I would suggest if you want to make it work. I have the next size up since I have 17gpm capability. Havnt done it yet but my plan is as yours. You can drive a bushog at speed, but cutting torque will be rather low before you surpass your tractor relief pressure setting and get a stall. Taking it easy tho and it could be real handy. Caution on the temptation to use the hog to trim high. ALWAYS keep the bushog tilted so you are not in the plane of the spinning blades.
...Also -- You will have to alternate valving to contol the loader while running the motor - interrupt motor flow while making adjustments. And, you will need a check valve across the motor ports to allow the motor to coast to a stop when valved off to avoid damaging it.
larry
I agree about the motor coasting to a stop, usually with a hydraulic motor you would use a motor spool valve instead of a cylinder valve. The OP might be just as well off using an over running clutch in his driveline too in addition to the check valves.
1065 (A53342)
1065 (A53342)
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2019 John Deere 1025R 24HP 4x4 Loader Utility Tractor (A52377)
2019 John Deere...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
