12 volt sprayer connection to BX2200
   / 12 volt sprayer connection to BX2200 #1
jblackwell
N/W Arkansas
Kubota B2620
Is there a 12-volt connection at the back of a BX2200 that I can connect a sprayer to? If not, where is the best place to get 12-volts?
Thanks,
jb
   / 12 volt sprayer connection to BX2200 #2
I don't have a BX, but I simply wired in a 12-volt cigarette type outlet on 2 tractors. I included a water proof switch so I can turn my sprayer on or off as needed. The 12-volt outlets are plastic waterproof units and designed for use in exposed pick up truck beds. The switches are from a marine supplier. All the wiring is run to the alternator stub, has inline fuses, and is not tapped into the tractor wiring block.
Waterproof 12-volt outlet mounted to NH
12-volt outlet mounted on Kubota
Waterproof switches on NH
Waterproof Switch on Kubota
   / 12 volt sprayer connection to BX2200 #3
I know my BX2230 if you flip up the seat there is a pair of bullet conectors for that purpose. But if you need to add power it IS easy see above
   / 12 volt sprayer connection to BX2200 #4
only one of the two wires are for powering a rear lamp. The other is for another tactor model and not used on the BX. If you ground it, a light will illuminate on the dash. The BX doesn't use that wire for anything.
   / 12 volt sprayer connection to BX2200 #5
To expand on Junkman's reply, The wire you want supplies 12vdc with the ignition key "on" and 0 volts with the key "off". Use the frame for ground return.
On my BX23 theres a 20amp fuse in the dash just for this key-switch powered connection also.
The other wire in the connector isn't used on American marketed BX's from what I've read & been told.
Volfandt
That's what I was hoping for. Thanks for the good info.
John
   / 12 volt sprayer connection to BX2200 #7
</font><font color="blue" class="small">( only one of the two wires are for powering a rear lamp. The other is for another tactor model and not used on the BX. If you ground it, a light will illuminate on the dash. The BX doesn't use that wire for anything. )</font>
Thanks again Junkman would have fought that when hooking up my sprayer. /forums/images/graemlins/smile.gif
   / 12 volt sprayer connection to BX2200 #8
My NorthStar sprayer from N.H. Northern came with a an 18" two strand wire with U-terminals on the ends. These connect to the battery. There is a little plug on the other end. I just let this go over the screen between the operator's seat and the battery. This wire always stays connected, with about 4" hanging loose. The sprayer has a long wire which plugs into the short one.
I bought the type sprayer designed to bungee onto the back of an ATV. To use it, I attach my carry all to the 3ph, put a plank on the carry all, set the sprayer on the plank, and bungee the tank in place. Works well.
   / 12 volt sprayer connection to BX2200 #9
</font><font color="blue" class="small">( If you ground it, a light will illuminate on the dash. )</font>
Hey, you got me thinkin' bet this could be used for the light for the "drive around with the brake on crowd". I'll have to check that out.
   / 12 volt sprayer connection to BX2200 #10
Having become a new member of that crowd let us know !!! I found its very easy to leave the brake on when you are trying to run partial throttle for break in reasons /forums/images/graemlins/smile.gif
Barn Wood Picnic Table (A50515)
Barn Wood Picnic...
Road Brute Flat Deck Trailer (A50514)
Road Brute Flat...
2025 Platform Safety Basket Attachment (A50322)
2025 Platform...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
John Deere AMT 622 (A47384)
John Deere AMT 622...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
