1210 CHARGE LIGHT ON
   / 1210 CHARGE LIGHT ON #1
spankyscamp
Imperial, Mo
New Holland TC45DA
When tractor is running the charge light is on dim. With engine at mid range voltage at battery is at 14 volts. Every now and then battery is dead and have to jump to start. Replaced battery and voltage regulator and the light stays on dim. Pink wire from ign switch to starter went bad about two years ago cause the engine not to turn over, replaced wire and that is fixed. Any help would be appreciated.
   / 1210 CHARGE LIGHT ON #2
Re: 1200 CHARGE LIGHT ON
If your 1200 has a Hatachi alternator check to see if the brushes are stuck. My 1900 use to do this and I could tap on the alternator and the light would go out.
Bill
2009 Caterpillar 623G Motor Scraper, S/N CAT0634GADBY00493, Cat Turbo Diesel, 12,763 Hours (A59076)
2009 Caterpillar...
2017 Chevrolet Tahoe Multipurpose Vehicle (MPV), 179380 Miles (A56438)
2017 Chevrolet...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58216)
2014 TIELKE...
2014 Kia Optima Sedan (A56859)
2014 Kia Optima...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
BOX OF INDUSTRIAL SHUT-OFF VALVES (A58376)
BOX OF INDUSTRIAL...
