1211 No Spark
/ 1211 No Spark #1
makoshako
Hello All ... we have a 1211 with a Kohler motor that is used infrequently since we have a zero turn now ... the tractor always started (if you keep the battery charged), but one day it would not. I tried the usual things (getting gas, safety circuits) and then finally checked the spark. No Spark. I double checked the "Engine Off" safety switch that I knew of and all of them seemed fine.
Which safety circuits effect the ignition? Is there an electrical diagram out there somewhere? What ignition components could cause no spark.
Thanks in advance!
/ 1211 No Spark #2
Not sure if you found your answer but you should check your coil wire that's what was wrong with my 149 when I got it . It had a bare spot and was grounding out .
