13 year old tires, time to replace?
   / 13 year old tires, time to replace? #11
My first tractor was purchased new in 1982. When I traded it in - 2009 - the tires still had 3/4 of the tread remaining and otherwise were in good shape. Keep your tires out of the sun - except when using the tractor.
   / 13 year old tires, time to replace? #12
If you have TOO MUCH MONEY, then you can replace them, however small checking cracks will begin to show on most tires after about 10 years but they dont necessarily mean the tire needs to be replaced, especially on slow moving stuff.
My brother in law bought an old 8N Ford with original tires, good tread but cracks in the sidewall all the way to the cord and all over both tires completely. They still would hold air for over a week without adding any air. Unless you are constantly working on a slope with heavy loading, I wouldn't worry too much about it till the cracks were showing the cord inside.
   / 13 year old tires, time to replace? #13
The red 584 That I posted a pic of is my "go to" snow tractor,,
the rear tires were replaced due to reliability issues,,
I did not want to be 1/4 mile from the house, with the 584 blocking the driveway due to a rear flat, in 42 inches of snow,,,
:eek:
   / 13 year old tires, time to replace? #14
Run them till they start to act up then decide if you want to replace or repair.
Tubes can be expensive, tire boots are available and do work.
We are in the process of booting the tires and patching the tubes on a 4430 Deere,
520/85R38's at $1200+ a piece and tubes at $150 each breaking them down and repairing may not be fun but
it certainly is cost effective.
i use a tire service for that. I don't touch ag tires except to check the pressure. My 2004 M9 has the original rears, my 2006 M9 has original front and rear. Tires are expensive, especially the big ones. To reshod one of mine, the cost is about 1800 bucks. I run them until they won't grip and replace them. So far that hasn't happened. Firestones all around.
   / 13 year old tires, time to replace? #15
I have always wondered if using Armour all or son of a gun "protectant" once in a while would really help with the side checking.
   / 13 year old tires, time to replace? #16
Not really. the cracking / checking is the result of rubber degredation from ozone. Tire dressings are just a 'feel good' thing.
   / 13 year old tires, time to replace? #17
We used to but they are getting pricey, also they are always in a hurry.
When we broke one tire down it was one that a tire service had worked on and he had reinstalled the tube with the glue still a bit tacky,
the tube was trying to stick to the tire and one patch had come loose off the tube and was the cause of the leak we had.
We are able to take our time and clean the rim well and even repaint them so they look good.
The last tire they did for me was 10 years ago, at $250 to pump out the calcium replace a tube and reload that tire I decided it was time to expand my tools and capabilities.
A simple little pump, a liquid fill adapter, some buffer dies, glue and cleaners, a few patches and different sized boots and ready to go.
Almost forgot my manual screw type bead breaker that was almost $200 back then as I recall,I see them now for around a $100.
This was also when I decided no more liquid filled tires for me, we do still have some on farm.
Unfortunately this latest flat was a filled tire.
If you are getting your M9 reshod for $1800 that must be bias ply tires and smaller. Even a pair of good 18.4x30 radials would be more then that.
   / 13 year old tires, time to replace? #18
I prefer older tires over new ones. Around here it's easy to come into Osage Orange (hedge) and Locust thorns. As tires age the rubber hardens, and is much more resistant to the thorns.
   / 13 year old tires, time to replace? #19
My tractor is 10 years old now, I hope I never have to replace tires in my lifetime
   / 13 year old tires, time to replace? #20
On one of my tractors, the tires looked like a topography of the Grand Canyon they had so many checks and cracks. I ran them for 25 years when their treads finally wore out.
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A57453)
(1) HD 27ft x 24ft...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A56858)
2008 Ford E-350...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
1998 6ft. Utility Trailer (A56859)
1998 6ft. Utility...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
