135 lfit problems
   / 135 lfit problems
Year is 1969. Dipstick is on lift control side and is set on fast
   / 135 lfit problems #13
G,Day sgblazer2.
You have changed or cleaned the hydraulic filter and changed the hydraulic oil ??.
With the brushhog attached set the engine speed at about 12 /14 hundred r.p.m. and with the draft lever the one nearest the right hand wheel ALL THE WAY BACK .Move the POSITION CONTROL lever to TRANSPORT position and watch the top link ,you should see the top link PULL OUT of the cover about 1/4 Inch ,if it comes out more than that the draft spring requires adjustment .
TO CHECK this Set the position control to TRANSPORT ,set the engine to 12/14 hundred r.p.m. park brake on and go to the rear of the brushhog and try to lift it up ,if it lifts up this indicates that the draft spring is indeed the problem.
If possible it is best to keep tractors and implements undercover .
Happy Days
Hutch.
   / 135 lfit problems
G,Day sgblazer2.
Happy Days
Hutch.
yes, filter and fluid changed.
the top link doent move at all.
   / 135 lfit problems
would the o-ring on bottom of the filter cause any problems?
   / 135 lfit problems #16
I have a similar problem with a well described solution in another forum describing the adjustment of the "big spring". My tractor is a M245 but this part is the same as the 135
Start post
hi me again ok I pretty much got it figured out started out going to hook 6foot finishing mower to tractor it picked front wheels of mower just off the ground so I thought maybe the relief valve was stuck so tied a chain around the rear axle and rockshaft SNAP broke my good chain pump has lots of power then took top cover off to check what kind of adjustments are on that big spring that top link hooks to set that to what it say in the I&T manual put back together same dam thing pulled side cover off and fiddles with adjustments in there put back together tried and lifted mower about a foot off the ground stayed for a second then drifted back down finally pulled that big spring that hooks to top link outta the top cover it was really floppy heat the crap out of it and dunk in water a couple times pound with hammer to get that threaded rod unstuck tightened spring up and put back in top cover tried to lift mower again and no lifty finally cranked that goofy nut that holds that big spring in as far as I could get it WAHOOOOOOOOOOO sat there ALLLLL afternoon with tractor idling and mower 3 feet off the ground
End post
My MF service manual describes adjusting the "master control spring" by using special tool FT 358. I would like to know if anyone has successfully used any other tool than the FT 358. If not, I hope they are still available, but I would rather not buy one if I don't have to.
When I use a chain instead of a normal top link attached to a rod in the draw bar support holes directly below the normal top link spot, the 3 pt lifts my new 6 ft brush hog off the ground just fine. It also lifts light attachments fine. So I am sure it is the master spring. I want to use my hydraulic top link to get a little better control and want to go back to a hard top link. My brush hog has an articulated mechanism for going through dips so I don't need the chains any longer that I had for my old hog.
   / 135 lfit problems #17
G,Day sgblazer2. The O ring wont affect the performance of the hydraulics as such it may allow unfiltered oil to go through the pump but that would be all . You say the draft top link does not move at all I have never experienced that in all my 36 years working on Masseys ,you did have the brushhog on when you tested it ??. To remove the draft control spring assembly, step one is cut or remove the rubber boot ,it will be no good anyway,and it gets in the way when you are removing the adjusting nut. replace the rubber boot during overhaul Undo the small allen headed grub screw that locks the adjusting nut in place ,the grub screw can be found on the right hand side of the lift cover adjacent to the adjusting nut, undo about one /two turns Make sure you use a good fitting allen key . Next step is to spray lots of your favourite release oil,, LOTS. if you dont have the tool to undo the nut get a fairly large chisel and dull the sharp end on the grinder and use it on the thin part of the adjusting nut ,go back and forward till it starts to move ,this could take some time I have on occassion had to heat the nut red hot to get it to undo if you do use heat dont put water on it when the cast cover is HOT you will crack the cover. When you have the assembly out give the lot a good wash in petrol and look carefully between the u shaped yoke ,there is a rubber plug in there remove the plug and you will see a cross shape on the end of the shaft with a locking pin going through into the housing this stops the shaft turning,knock the pin out with a pin punch. Next try to undo the shaft using the cross on the end of the shaft again plenty of release oil and maybe a bit of heat. next clean everything up a wire wheel on the bench grinder is a good tool wear goggles and a mask and give everything a good clean ,dont forget to clean inside the lift cover where the spring assembly fits, be carefull there is a large support washer in there right at the end ,it has the draft sensing rod sticking throught it this is where the hydraulic system READS the movement of the linkage,once cleaned out and the large washer has fallen out GLUE it back in place with a big dob of grease . dont forget to give the thread a good clean with a wire brush. Next reassemble the draft link assembly ,same way as you stripped it again using the cross on the end of the shaft ,This part is important ,Tighten the spring by tightening the rod or should i say undoing the shaft until THE SPRING IS JUST NEAR IMPOSSIBLE TO TURN BY HAND NO MORE then line up the locating pin hole and knock the pin in. Plenty of grease on the adjusting nut and the thread in the housing, make sure the big washer has not fallen down then fit the assembly . Next again this part is important some think that by adjusting the spring all the way in is good this is not so and can affect the internal adjustments as has been mentioned in the previous post ,Install the assembly and ADJUST THE NUT TILL THE SPRING ASSEMBLY IS TIGHT AND KEEP GOING TILL IT STARTS TO RATTLE AND BECOME LOOSE AGAIN AT THIS POINT UNDO AGAIN TILL THE ASSEMBLY HAS NO SLACK,Lock the allen grub screw and reconnect the two yoke bolts . That is the draft top link adjusted . refit the implement and try you will see the draft toplink extend about 1/8 th to 1/4 inch depending on the weight of the implement,again set the draft lever all the way back and leave it there ,using the position control and if the hydraulics are all good the three point linkage will respond exactly as per the movement of the lever example move the lever UP a little bit and the linkage will raise a little bit and STAY THERE and so on. Set the response control lever ,on the right hand sideplate next to the transmissoin oil dipstick by raising the brushhog to the transport position and setting the response lever t o the SLOW position and then lowreing the position control lever you may find that the linkage will not go down SLOWLY move the resonse lever towards the fast position until you are happy with the rate of drop,incidentally this rate of drop will also affect the response of the brushhog i.e how fast it responds to up and down movement on uneven ground ,you may want it to respond faster ,you know how to do this. thats all . It has been suggested that you can use the draft control lever for the brushhog ,using the draft lever will not give you positive response,the correct way to operate is to use the position control . Happy Days Hutch.
   / 135 lfit problems #18
I doubt that the o-ring is the source of your problem. Did you get all the diesel flushed out of the hydraulic system? Did you use the correct hydraulic fluid?
   / 135 lfit problems #19
Hutch,
Very impressive write up. Wow. Thank you for documenting this.
   / 135 lfit problems
Just an update;
Turns out the draft control spring was out of adjustment and the adjusting nut was frozen in place, also the linkage for the draft control and lift control needed to be replaced. There were no leaks coming from the stand tube or cylinder, but it still has some excessive leak down after cutting the tractor off, so i guess its in the pump, but it still picks up my 900lbs harrow, so we're good for now.
Thanks guys for all the help!
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
Two Post Car Lift (A50120)
Two Post Car Lift...
2239 (A51244)
2239 (A51244)
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53473)
2006 Magnolia Dry...
2008 FREIGHTLINER M2 106 (A53843)
2008 FREIGHTLINER...
