14.9 x 26 Ag tires - mounted
   / 14.9 x 26 Ag tires - mounted #1
Michael_C
Bronze Member
Morgan Hill, California
Kubota L5030,Gearmore
I just purchased a 2003 Kuboa L5030 which came with turf tires - I will be pulling a disc with it and suspect the turf tires will have some problem gripping and am looking to see if there is a used set for sale. Anyone know of a good site to be watching?
   / 14.9 x 26 Ag tires - mounted #2
That is an odd size tire. New ones are very expensive compared to a 24 or 28 inch rim. I do have an answer for you though: Allis Chalmers D14's and D15's commonly use that size. Some Gleaner combines used a 26 inch rim also but I think the width was 16.9 or 18.x I would post a "wanted" question in the discussion forum at www.allischalmers.com good luck
   / 14.9 x 26 Ag tires - mounted #3
As Gene said that is sort of an odd sized tire. I have them on an old IH, but they are commonly found on older combines and such. A local dealer quoted $365 each to me !!!
I am on the lookout as well...Missed a good pair at an auction a while back that went for $120 mounted on nice rims /forums/images/graemlins/frown.gif
I would have paid $300 for the pair.
Ben
   / 14.9 x 26 Ag tires - mounted #4
I do believe that the tractor is a four wheel drive and if this is the case, all four tires need to be replaced, not just the rears.
If I am reading the price list correctly from the MN state site, you should be able to pick up all four including the rims from a Kubota dealer for $940.00.
   / 14.9 x 26 Ag tires - mounted #5
Unfortunatly dumbdog this is not the case. It is a few grand for all 4.
There is a 28" tire and rim option for the L5030 I think you'll find is the normal one the dealers order.
We had the dealer swap off the turfs when we bought our 5030 but we went with R-4's.
Thanks for the information - Would going with a 28 inch tire open the door to better pricing, or just better availability? Any idea what size the front has to be (with 28" rear tires)? I would think the fronts would end up being an odd size to keep the ratio the same.
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
Deutz 2WD 53HP Utility Tractor (A51691)
Deutz 2WD 53HP...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A51572)
2014 Ford F-150...
New/Unused AGT YSRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
