284 International
Veteran Member
- Joined
- Jun 28, 2010
- Messages
- 1,464
- Tractor
- International Harvester 284
For a change, I have a question about a comparison between tractor models, rather than some maintenance or repair issue. A friend is looking at a Yanmar 186D. He has some implements (Brush-hog and disk harrow with roller) already. We have tried my 1401D on them, but they are just a bit too large/heavy for it.
It pulls them fine (Mine has a loader so the front end really works well in assisting with the tractive effort), but they are just a smidgen heavy, and everything is just a bit too large dimensionally, like the spread between the hitch points, and vertical separation between the top link and the lower arms.
The 1401D also can just barely lift them-they are fairly long, so they have a lot of leverage, and the disk weighs too much with any ballast on it to lift. Empty it's fine, but with 80 lbs of ballast it won't lift, and the system goes into bypass.
The issue is whether there is enough of a difference in capability between the two tractors to make it worth his while to invest in the 186D, or if he needs something larger. As mentioned, it isn't a traction or pulling issue, it's more about dimensions and lifting ability.
The implements could possibly be adapted to fit a smaller dimensioned tractor (The brush-hog easily by switching the direction of the pins, the disk would be a problem since it has a cast frame up front) so that isn't a huge issue, it's more about the lifting capacity. The specs on both come out to within an inch or so in most dimensions, but the 186D is listed about 250lbs heavier. 250 pounds isn't that much, except it's over 20% heavier than the 1401D is. The hydraulic pumps are the same according to parts from Hoye.
Sorry for being so long-winded, here are my exact questions: Is the 186D significantly heavier-duty and able to lift and handle more load than the 1401D? Are the three point dimensions the same? (Spare parts are listed the same from Hoye, but that doesn't mean the mounting dimensions are identical.)
