1428 Slooooooooowwwww reverse, can it be speed up?
   / 1428 Slooooooooowwwww reverse, can it be speed up? #1
DuaneW
Bronze Member
1428V Hydro, I often find myself in high range just because reverse is so darned slow, any way you can speed up reverse in ALL THREE RANGES?
And I dont need lectures on going fast in reverse being dangerous and all, some jobs simply take to long with the slow reverse in this thing.
Thanks,
DuaneW.
   / 1428 Slooooooooowwwww reverse, can it be speed up? #2
On the hydro model 1428, reverse should be 80% as fast as forward for safety reasons. There is a stop bolt that limits the amount of hydro pedal travel that can be adjusted. NOTE: If the stop bolt for forward or reverse is adjusted too far allowing swash plate to "bottom out" internally, you may find yourself buting a new hydro. Suggest you purcahse a service manual and verify pedal adjustment is correct.
If it was 80% as fast, or 20% slower I would be HAPPY, Will talk to my dealer since speeds are supposed to be that close, reverse in High is about 1/2 speed of low range. And you really have to stand on the pedel to get that out of it.
Thanks,
DuaneW.
New/Unused 8in Bucket (A57454)
New/Unused 8in...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
2007 Ford F-750 2,000 Gallon Water Truck (A55973)
2007 Ford F-750...
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
