1428 Slooooooooowwwww reverse, can it be speed up?
   / 1428 Slooooooooowwwww reverse, can it be speed up? #1
DuaneW
1428V Hydro, I often find myself in high range just because reverse is so darned slow, any way you can speed up reverse in ALL THREE RANGES?
And I dont need lectures on going fast in reverse being dangerous and all, some jobs simply take to long with the slow reverse in this thing.
Thanks,
DuaneW.
   / 1428 Slooooooooowwwww reverse, can it be speed up? #2
On the hydro model 1428, reverse should be 80% as fast as forward for safety reasons. There is a stop bolt that limits the amount of hydro pedal travel that can be adjusted. NOTE: If the stop bolt for forward or reverse is adjusted too far allowing swash plate to "bottom out" internally, you may find yourself buting a new hydro. Suggest you purcahse a service manual and verify pedal adjustment is correct.
If it was 80% as fast, or 20% slower I would be HAPPY, Will talk to my dealer since speeds are supposed to be that close, reverse in High is about 1/2 speed of low range. And you really have to stand on the pedel to get that out of it.
Thanks,
DuaneW.
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2018 Komatsu GD655-6 Motor Grader, S/N 60403, PIN# KMTGD032PJA060403, Turbo Diesel Engine, 14' (A59076)
2018 Komatsu...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
JOHN DEERE LOADER LINKAGE (A52708)
JOHN DEERE LOADER...
2007 PETERBILT 385 CAB AND CHASSIS (A58214)
2007 PETERBILT 385...
