3-Point Hitch 1500D 3 point hitch control valve?
   / 1500D 3 point hitch control valve? #11
Onthesauk said:
I recently changed the hydraulic fluid and cleaned the filter on my 1500D. I used it one time since then for a couple of hours to till the garden and everything worked fine. Today I used in for half an hour and when I put it away, the 3 point hitch wouldn't go down. Appears the pin on the back of the hydraulic control valve free floats.
Entire assembly is available from a dealer but quite expensive. Wondering if there is any other alternative, i.e. dismantle and clean?
OTS, I had the same condition on my 1610D, as I also had a 1500 with the same
3pt valve I decided to try a switch. After I removed the valve from each of them I realized that the spool in the 1610 valve was stuck in the valve body. I carefully beat it out using a piece of dowel as a punch. I polished the spool with emery and lubed with wd 40 it would then move freely in the valve. I reassembled it and have had no trouble with it since.
Thanks Suds, that may be my first try.
My tractor expert down the street suggested maybe an air bubble. I used the tractor hard for a couple hours after changing the fluid so hard to imagine that any air wouldn't have worked it's way out. Anyone experienced this?
Got a replacement hydraulic control valve from Hoye yesterday, installed today, took about an hour and everything works fine again.
Thanks for everyone's help!
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2012 Honda Accord LX Sedan (A51694)
2012 Honda Accord...
5ft Set of Disc Harrows (A51573)
5ft Set of Disc...
