1528 with fel ... 9X3 Transmission question
   / 1528 with fel ... 9X3 Transmission question #1
20acres
Blue Ridge Mtns, VA.
L3130DT (4WD) canopy
Where is the gear lever located on this tractor? I suppose to test drive one today but the dealer on has a hydro.
I'll be comparing against L3130 and FarmTrac 300DTC.
The 1533 was about 1300.00 higer than the Kubota.
The FarmTrac is about that much lower than the Kubota.
T Y
   / 1528 with fel ... 9X3 Transmission question #2
9 x 3 gears I believe are located on the left side of seat, inside of fender, or at least thats where they are on the MF 1523. They are not under the seat like I think some of the older model Massey "compacts" were.
   / 1528 with fel ... 9X3 Transmission question #3
Both are on the LH side incorpoated into the LH fender. Range lever is an inline shifter. Transmission lever is an H pattern (1, 2, 3, R). Makes getting on and off the tractor a breeze.
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2012 FORD F150 XL SINGLE CAB TRUCK (A51406)
2012 FORD F150 XL...
2019 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2019 Top Hat...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
Toro Zero Turn (A50324)
Toro Zero Turn...
