let me add this one more bit of info concerning using a flatbed trailer, actually its Kinda more of a story than info
when I sold my CUT Kubota the man showed up with a Barrowed very heavy duty built 20 ft flatbed trailer, the kind you see painted yellow and might see with a Heavy skid loader or sort, the deck must have set 2 1/2 feet off ground level,
it had looked to be 6ft ramps,
The buyer climbed aboard the Kubota and started up the ramps all was well so far , Now I must note: I sold the tractor with a Brush cutter and he test it out on flat ground with no front lifting problems.... as he topped the ramps the front wheels came up and there he was with the front of the tractor balanced in mid air, He had the clutch in and the brakes applied litterly scared to move...........
Because of the angle of the ramps he had set the brush cutter to lift as far as it could go , it was luck that I had climbed up on the trailer moments before to help guide him up, after a few seconds I could see the front wasn't coming back down on its own and I was afraid it might head over backwords
at first I was reluctant but i went ahead and jumped up on the front bumper and brought the tractor back down,
OK! I'm sure Loading the tractor might not have been a problem if had ballast on the front, But then again who could say how much ballast would have been needed? My 230lb barely brought it back down while being in the angle it was in,
Now when the tractor was out flat level on the ground there was no indication of the front ever coming up, although once the tractor reached a certain angle on the ramps its weight shift to the rear causing the front to lift once the wheels went over the top of the ramp,
Whether or not this would have happen with a Dovetail trailer I couldn't be 100% certain, But I would think that perhaps the chances would be lesser on a shallower angle of a dovetail and of a more leveled out ramp
just saying
Incidentally in fear of the buyer once getting home unloading the tractor and possibly injuring/Killing himself,
I went ahead and threw in a Chunk of R/R track I used for ballast, although never did hear if he got it unloaded safely or not
End of story
