I had to redo the wiring on my 1700 as it was so 'rigged' that nothing worked on it.
Essentially all you need to do is run wires. Many times a wire will vibrate thru on an edge, near the 'firewall' if you will. Also check to see if any auxiliary circuits have been run off of that circuit. I've seen people splice all kinds of things into low amperage circuits... like lights off of ignition, etc...
If nothing else, try a bypass. Find the bat. terminal, run a wire to the fuse block, then to the gauges. If all works, reverse engineere the existing wiring till you find the fault.
Often when I am trying to trouble shoot lines with constantly blowing fuses, I will pop out the fuse, and hook in an automotive light.. or test light. As long as it stays lit.. I know I still have a short. I then start at the original load ( gauge, light, coil, whatever), and start un hooking one connection at a time till the light goes out. When it does go out.. the piece in your hand is the bad part.. or connected to it.
Soundguy
