1610D low and wide
   / 1610D low and wide #21
I got the Turf Tire Set from Hoye. I did some research but wasn't able to make it any cheaper unless I did some major fabricating and to me it wasn't worth my time to chop things up. Not that I didn't want to purchase from Hoye, but sometimes money is tight. Anyways I went with his setup and love it. No problems and I love the added traction and its easy on the grassy areas you don't want to ruin and great in the snow so far the last 2 years.
Thanks for the info. Definitely like the look and wider stance that setup gives you. I will probably order the same setup from Hoye as well. The tires themselves that come with the kit, are they a straight turf pattern ? Also curious as to what brand they are. Titan, Carlisle, Imports?
   / 1610D low and wide #22
Yes the wider stance is nice, and so is the extra footprint. I believe the tires I have are Carlisle, and they are a straight turf pattern. I liked it so much that when I bought my 155d I put a turf kit on there as well.
   / 1610D low and wide #23
Thanks! Definitely going that way this winter so I’m ready for another mowing season when spring gets here in 5 or 6 months.
   / 1610D low and wide #24
Yes those wider turf tires are great in snow and on the turf.
   / 1610D low and wide #25
I’ll tell you I really love the 2210D. Used it all summer with a light weight 4 foot brush hog to mow my field. Really a handy sized tractor to have. I’ll tell you that 2 cylinder is a real thumper. Love the simplicity and the quality that makes these old tractors still very viable today.
   / 1610D low and wide #26
Yep I love my 2210D too. I use my on a regular basis to move trailers, haul wood in the loader or scoop manure. I have a 5.5 ft tiller I use in the summer and a 5.5 ft snowblower in the winter, I will say that little 2 cylinder really works nice and like you said simple too.
Clemco 150psi Portable Sand Blasting Machine (A55973)
Clemco 150psi...
2014 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2014 DRAGON 130...
2016 GENIE Z80/60 TELESCOPIC BOOM LIFT (A52709)
2016 GENIE Z80/60...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
1997 Perkins 75KW Towable Diesel Generator (A56857)
1997 Perkins 75KW...
Mini-Excavator Heavy Duty Weed, Brush, and Rock Rake (New/Unused) (A59225)
Mini-Excavator...
