1643 Lift capacity
   / 1643 Lift capacity #11
Your loader lift capacity is around 1314 lbs.
You would have to have remove 600 lbs, which amounted to 15 bags @40 lbs
Here are the loader specs.
If all the weight was on the pins, you could lift about 1900 lbs.
If you know the pump specs, check the PRV relief pressure, and see if it is about 50 psi below the pump pressure. A 100 psi difference will add 314 lbs of lifting power to each cyl.
Loader:
Loader type: Massey Ferguson DL120
Height (to pin): 102 inches [259 cm]
Dump angle: 47
Rollback angle: 30
Breakout force (bucket): 1,841 lbs [835 kg]
Lift to full height (at pin): 1,900 lbs [861 kg]
Lift to full height (at 500mm): 1,314 lbs [596 kg]
   / 1643 Lift capacity #12
You should have nothing to complain about:thumbsup:
Your tractor is rated for 1314lbs @ 500mm forward. What THAT means: your tractor is rated to lift that much, 500mm (19.7") forward of where the pin attaches the forks to the loader arm.
Since you have a QA, that deducts weight and also shifts it more forward. The center of your load was probabally in the 25" forward range, and you were still able to lift more than 100lbs OVER the rated capacity.
Nothing to be disappointed about at all.
As big as out CUT's look, for their size they are light. And they arent ment to be forklifts.
We have a forklift where I work that is pretty small. size wise, it would probabally fit in the bed of a P/u. Yet is has more lift capacity than 100+HP tractor loaders.
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
Mini Excavator Bucket (A55272)
Mini Excavator...
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
(13) NEW TRUSSES (A58376)
(13) NEW TRUSSES...
Hydraulic Dingo Trencher Attachment (A55272)
Hydraulic Dingo...
2012 UTILITY TRAILER MANUFACTURER FLATBED (CRACKED FRAME) (A58214)
2012 UTILITY...
