1660 shutting down
   / 1660 shutting down #11
I am leaning more toward ignition related only because its killing the dash lights and the neutral switch is tied in on the start side. The dash lights and fuel shutoff solenoid is tied to the run side.
I guess you have made sure its plugged in good.
I would also unplug it, remove it and look for a loose pin on the switch itself.
It would help me to better understand if you can answer these:
does it ever do it sitting still idling or does it always do it while you are working (moving).
does it kill the radio
does it kill the blower motor on the heat/ac
does it ever start to die and then misfire and begin running fine again
how long in between incidents every 5 minutes every hour is it getting worse as to when it does it.
Also I have seen people try and turn the key to far to the left when shutting it off and messing up the internals of the switch making it loose fitting and sloppy.
Are you the first owner of this tractor?
You dont have a wad of keys hanging on the key chain as Mike476 mentioned earlier.
Have you found mouse crap/ mouse nest anywhere in the cab - could be a chewed up wire.
Sorry for all the questions
Just an update, after testing the ignition switch, I found a loose spot that would lose contact when the key was wiggled. My dealer sent me a new switch, I replaced it and problem is gone.
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
49205 (A55788)
49205 (A55788)
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
Deere 310L (A53317)
Deere 310L (A53317)
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2018 FREIGHTLINER...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
