16hp Vanguard Flywheel
   / 16hp Vanguard Flywheel
I hope so, that's the one I ordered. Will update later...
Thanks for the catch... I did mean a 350447 1206-E1. The original part number was BS-808082 and that became BS 843977, according to the Cub Cadet parts diagram and the Web. The B&S link in this threat shows it also as 690911... Unfortunately it is unavailable under any of those three numbers. Suggestions welcome. The part I have has its blades, but the plastic mounts that held the rotating screen are broken off. I wonder if I could just operate the engine without the screen? CC has ascreen over the whole area, but I guess stuff could get sucked in still.
You could run it without the screen. It will probably suck more grass through there, but if you have access to compressed air you could blow it out good after use. Otherwise, you're probably in my boat, only way to replace is to find an original used one.
   / 16hp Vanguard Flywheel #13
Just a note ... Found the "no longer available" flywheel fan at Sears Parts... They found it in some Mid-Western repair shop's back room. Came in a filthy old box, but fits perfectly. Got a new crankshaft and some used parts and am putting it all back together now.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2025 Auger Skid Steer Attachment (A53421)
2025 Auger Skid...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
