16LA loader operation question
   / 16LA loader operation question #11
daTeacha said:
That "speed increaser for when you dump" is also on my LX114 on the Case. It doesn't seem to make a whole lot of difference, about .1 or .2 second with a full load. I kind of wondered why they bothered with it except to make something sound good in the literature. The dump speed seems fast enough without it.
Who really needs a superfast dump feature anyways? Seriously, what is the advantage, even if it's a half second faster? Will that little bit of time really let anyone get more work done in a day? If the normal dump time was 6 or 7 seconds, there might be some reason for a fast dump, but mine is pretty quick without the feature.
I find that feature very useful. The increased speed gives just enough extra momentum to flick out sticky clay or manure. Kind of like the difference between trying to flick a booger off you pinky or flicking it off your index finger. That extra little bit really helps.
   / 16LA loader operation question #12
hi all, my thinking is the 'speed increaser' sounds like a 'double acting' cylinder that uses hydraulic pressure (from the pump) along with the simple relief value to drain/retract the fluid/cylinder into the reservoir.. (?)
the thingy to increase (if that's "marketed" as something {super extend?}) would be a 'Regenerative' circuit that links the draining fluid back into the extending port (?)
2017 GENIE GS-2646 (A52472)
2017 GENIE GS-2646...
2018 Wacker Neuson WL 38 (A52748)
2018 Wacker Neuson...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
