jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 21,059
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
Flatheadyoungin said:I think I've asked this before but the title of the thread probably didn't help.
On my FEL and on my BH, I can only do one movement at a time. I have a TC45 shuttle. I have 4 hyd. hookups in the front for the FEL. There is a single hookup under the belly of tractor. There is a single above the rear axle and there are 4 more quick connects at the rear. Am I using the wrong ones?
A friend of mine has a TC35 hydro and I jumped on it again the other day just to see if his would do two motions, and it did.
Sure this thing will do two things at once......
HELP!!
Think of a hose with a "Y" connection in it and two nozzles on the end of the "Y". If you open one nozzle, you get full pressure and flow. If you open both nozzles and the length of the hoses are equal and the nozzles open exactly the same, you will get about the same flow as before (total gpm) if you add the flow from both nozzles, but either nozzle will only have half the pressure. Are you with me?
Okay, lets say that this is a magic "Y" in this hose so that the left nozzle when open also closes off the nozzle on the right. Even if you have the right nozzle going full blast, when you open the left nozzle, it sprays and cuts off the right nozzle. The more the left nozzle opens, the more the right nozzle is turned off. Still with me?
Lets talk FEL loader double spool valve (joystick valve). To make a comparison to my hose example, the bucket curl is the "left nozzle" and the bucket raise is the "right nozzle." If we can get them both open equally and all things are equal, they will both operate, but each with half flow and half pressure. But like two nozzles running on a hose, if I reach up and put my thumb over the end of one nozzle, it's flow stops and the other one spurts all the water. Now back to the FEL. If there is equal pressure to both curl and lift, then the resistance must be equal for both to operate at the same speed. If it takes significantly more pressure to raise than to curl, then you will see much more curl.
Finally, your double spool loader valve is like that "magic Y" adapter. Because the curl spool is first in line to the hydraulic flow, it can shut off all flow to the lift spool if it is opened all the way up. The more you open it, the more you cut off fluid to the lift spool. As a matter of fact, all other hydraulic actions on your tractor are preceded by the curl spool. (I could be wrong about the BH, but I don't think so.) I know that your 3PH and single rear remotes will not operate because all the hydraulic pressure and flow is going to the curl spool if you have it wide open. It's first in line, so it has ultimate control.
Now, why does your friends TC35D and many others of us have dual motion? It's probably a case of how well broke-in our valves are and how we have learned to feel and feather the controls. You also did not tell us the exact conditions under which you tried your friend's loader. Was the bucket empty. Has yours been empty? I would suggest putting a small load into the bucket and then trying to learn the feel of your joystick. The load in the bucket will provide a backpressure load to the lift spool if you don't open the valve too far. That should cause both axes to operate at the same time. Though, like my buddy mikim said, it ain't gonna be too fast. It can't be because you are splitting your flow between those two sides of the "Y".
Is anybody still awake, or have I put everyone to sleep as usual?
