16xx series - where to adjust hydraulic pressure?
   / 16xx series - where to adjust hydraulic pressure? #1
TSO
Elite Member
SouthEast Michigan
Massey 1652 HST Cab
I've had the tractor for about a year now, and I finally now have a hydraulic pressure gauge on the way to check the system while I go over everything for routine maintenance this winter. Can anyone point me to where I would adjust hydraulic pressure if it was needed?
And, are my rear remotes the best place to check the pressure, or am I better off using the loader circuit?
Thanks in advance!
Bump ...
   / 16xx series - where to adjust hydraulic pressure? #3
Do you think your pressure is low or you want to just bump it up a bit? You should be fine checking at the loader valve quick connects.
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2877 (A58376)
2877 (A58376)
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
MMS SDLOOL Remote Control Mower (A57149)
MMS SDLOOL Remote...
SDLanch 12'x20' High-End Carport (A57149)
SDLanch 12'x20'...
