1700 rear axle housing
   / 1700 rear axle housing #11
No, I emailed about it and Aaron returned my email.
   / 1700 rear axle housing #12
To follow up on my loosened lower hinge pin problem, my threads were not exactly umdamaged. I found that by removing the nut I could screw the pin in about 3/16" deeper into 3 or 4 new threads and still have room to install the lower link, If the nut were 3/16" thinner. I undercut the nut by 3/16" with a Dremel tool, slathered the whole thing with JB KWIK, put it back together as tight as I could get with a 12" adj. wrtench, tweaked it with a 4' pipe, and worked all day yesterday, boxblading, with no problem. If it loosens, I will order the hinge pin kit. I might add, I thought I had been diligently greasing my tractor, but there was not a drop of grease on those hinge pins.
Just a quick update on my axle housing problem. I disassembled the housing just so i could get to the damaged part easier and on the bench, I figured that it would be easier to drill and work on if it was off the tractor, in the meantime i contacted a few parts suppliers from this board and was pleasantly surprised at the prce for a good used housing that fredricks eq. quoted me so after pricing helicoils and what not i was nearly the same price replacing the housing. I ordered the part tuesday at 4pm and it arrived friday morning at 9am kudos to all the people at fredericks for a job well done.
thanks to all who responded and by the way if anyone needs an axle housing (slightly damaged i will make ya a heck of a deal LoL)
thanks again
john
2009 Lincoln MKS Sedan (A51694)
2009 Lincoln MKS...
UNUSED FUTURE 15" EXCAVATOR GRAPPLE (A51248)
UNUSED FUTURE 15"...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2024 Kearney 7'x20' Trailer (A50123)
2024 Kearney...
2020 JOHN DEERE 8R 250 LOT NUMBER 228 (A53084)
2020 JOHN DEERE 8R...
2025 AGT LRT23 (A50123)
2025 AGT LRT23...
