1700ym-High gears are getting weak and pto is weak??
   / 1700ym-High gears are getting weak and pto is weak?? #11
Adjust the turnbuckle shown in this drawing so the clutch pedal has appx 5/8" free travel from top to the point you can feel it making contact. If your adjustment is close to that then your clutch is likely toast. CLUTCH: Yanmar Tractor Parts
   / 1700ym-High gears are getting weak and pto is weak?? #12
Are you getting crankcase blowby?
With the head off was the injector and glow plug checked?
No sir, I do not believe so.
   / 1700ym-High gears are getting weak and pto is weak?? #14
Compression problem alright and with a screw in it Dang!!! The screw is different but seen it happen before but a major repair when putting it back together. Glad your guy caught it. I don't think you have a Clutch problem but if it does have a lot of play in the pedal then Adj. it. I have the same Org. Trans/clutch setup as you do and what I did was set my pedal free play to about an 1/8" before you feel pressure. That was 10 Yrs. ago and 600 hrs. on the tack. But I am a firm believer that if it ain't broke don't fix it.
   / 1700ym-High gears are getting weak and pto is weak?? #15
So the cylinder walls were not scratched? You knew this screw fell in I guess, so it was never run with it in the motor then I guess. IF it wasnt run with it in the motor I doubt it did much if any damage.
   / 1700ym-High gears are getting weak and pto is weak?? #16
Took the head off and sitting on top of the piston was a darn screw and it had made a impression of it in the top. We removed the screw and he smoothed it up.
When I shift into any gear it has been grinding a bit.
Sure Sounds like it was running. Hard to grind the gears shifting with it not!!
   / 1700ym-High gears are getting weak and pto is weak?? #17
More info needed. Does the engine speed slow down along with the tractor and pto speed?
   / 1700ym-High gears are getting weak and pto is weak?? #18
That would be some good info. or even better like I asked does the Rpms go up or wide open and the mower and tractor slow down.
   / 1700ym-High gears are getting weak and pto is weak?? #19
Yep those questions answered would be good.
Also no matter how much that screw trashed or not trashed the piston , cylinder walls, or head that in no way translates to your gear grinding.
That sounds almost like a clutch is not disengaging right? These are not schronized transmissions so some grinding is somewhat normal. Not excessive but a quick grind when shifting is not uncommon.
I have not noticed the engine slowing down at all. Only the rotation of the pto and the speed of the tractor, not the engine. Thanks again for everyone's time and comments!
2853 (A58376)
2853 (A58376)
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2025 Yakta YXR970 Zero Turn Mower (A57453)
2025 Yakta YXR970...
1996 International Water Truck with a Caterpillar Engine (A56438)
1996 International...
1617 (A58375)
1617 (A58375)
