1720 Rear Remotes
   / 1720 Rear Remotes #1
Litdave
I have a '98 1720 and would like to add rear remotes to it for top-n-tilt. I called my local NH dealer and he says NH no longer sells a kit for the 1720 through whole goods.
Does anybody know if a kit for a tc30, tc29 or tc33 could be made to work?
   / 1720 Rear Remotes
Anyone have any ideas?
   / 1720 Rear Remotes #3
Dave, sorry I can't help but I'm watching your post and hoping someone knowlegable will reply. I have a 1920 and was also hoping to add a rear remote (or two). I called the local dealer and got a quote for over $600 for parts only! I've read here that guys are adding the first remote to Boomers for under $300.
   / 1720 Rear Remotes #4
You can always add an aftermarket valve and plumb it using the power beyond from the loader's valve. This assumes the 1720/1920 are similar to today's tractors hydraulic systems.
   / 1720 Rear Remotes #5
I have a 7308 FEL. I did not know that going off the FEL joystick (valve) was the way this is done. If i run off the FEL power beyond port will I still have full use of the loader? I want a rear romote to turn the chute of a snowblower and need use of the FEL to pile snow.
   / 1720 Rear Remotes #6
</font><font color="blue" class="small">( If i run off the FEL power beyond port will I still have full use of the loader? )</font>
Yep, No problem.
I have posted the instructions on how to plumb this up a dozen or more times in various forums here on TBN. You can pickup the valve, hoses and fittings for about $400 depending on how many spools you want. Surplus Center has Prince SV valves that will work just fine. If you need configuration info PM me.
2013 CATERPILLAR 316EL EXCAVATOR (A52709)
2013 CATERPILLAR...
Toro Greensmaster 3150-Q Riding Mower (A56859)
Toro Greensmaster...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
3PT SCOOP PAN (A58374)
Hyster H80FT 8,000LB Forklift (A56857)
Hyster H80FT...
2001 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W41X143155 (A57453)
2001 Ford Crown...
