1720 won't start - should try to bypass key switch?
   / 1720 won't start - should try to bypass key switch? #11
Oh if I remember I think, one trouble I had was the flat braided wire from the battery it was also completely corroded off the terminal. I replaced mine with a stranded rubber coated one..
Chopped,
Yes, I too have the uncoated braided (-) negative ground cable. But it appears to be fine....
Kirkawilson,
How do I "start with the neutral safety switch"? Where is it located and what do I do when I find it?
BarnieTrk
   / 1720 won't start - should try to bypass key switch? #13
Chopped,
Kirkawilson,
BarnieTrk
HMM I believe you'd remove the dash casing around the shifter levers under the steering wheel..Assuming its a geared tractor.It would I imagine be near one of those levers . tractor shifter.JPG
   / 1720 won't start - should try to bypass key switch? #14
If it's not dirty connections, then then next thing to check is the cable. Cables can look like new on the outside, but have a severely corroded core hidden by the shiny red vinyl jacket.
   / 1720 won't start - should try to bypass key switch? #15
Mine did the same thing. Neutral safety switch on the forward reverse column shifter.
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
Kubota M108S (A53317)
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
378721 (A54865)
378721 (A54865)
