18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust
   / 18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust #11
That was a couple of years ago...........don't recall having to adjust the carb.
Did it run better..........?.......eh.........maybe...........sounded great though.
   / 18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust #13
Check the governed RPM. Increase it by a couple hundred RPM to produce more power. Just about everything will shorten the engine life. You can go to sythetic oils to increase protection?
   / 18hp Kawasaki engine on a zero turn and was wondering if I dual exhaust #14
I think I'd just have the heads shaved about 0.030 - bumping the compression ratio about 1/2 pt. You'll see a difference then :)
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2020 CATERPILLAR...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
TANK MANIFOLD (A55745)
2016 JOHN DEERE 310SL BACKHOE (A52709)
2016 JOHN DEERE...
2019 F150 (A56435)
2019 F150 (A56435)
